[Closed] BB help
[#588963]
Ok normally I can get a BB in by hand to the end it turns twice then jams... I have cleaned both BB and the BB housing, LBS job? all threads look fine
Posted : 28/05/2009 11:05 pm
Try another BB to see what happens. Sometimes it removes that infinitesmally small bit of grit that's causing the problem - assuming you are not cross threading it 🙂
Posted : 29/05/2009 12:17 am
What epi said but having a bb cleaned and faced up by LBS might be a good thing.
Posted : 29/05/2009 12:53 am
 PJay
I find BB threads suprisingly delicate and easy to cross, so I always make the point of threading them in by hand. They need to go in really straight and on mine, if they don't, they stop after a couple of turns; I guess the threads begin to cross. I don't know what sort of BB you're fitting but I still use Octalink cartridge units and find that popping a finger into the axle on the far side when threading them in helps to keep things straight. Cleaning up the threads sounds a good idea too (both the BB itself and the shell).
Posted : 29/05/2009 8:04 am
I was fitting a RF x-type, never had a problem prob nstalled over 30 of them but this is stuck, but off to the LBS today to make sure I dont damage the frame, I only tried by hand 2 turns, just hoping it is not the frame I just brought.......................
Posted : 29/05/2009 8:59 am
