Bar congestion !! o...
[Closed] Bar congestion !! options needed
[#5139371]
I have decided to switch from 1x10 - 2x10 and having been use to running my reverb on the left(rh lever). Upon fitting the front shifter i seem to have little room, if any to fit the reverb remote without it seeming to far inboard. i'm running xt m758 brake and xtr m780 shifters. Has anyone got the same setup ? how have you got it all placed ? Pics would be good. 🙂
Posted : 09/05/2013 6:47 am
You will have to fit it on the right hand side the correct way up.
I have one on my running 1 x 10 and it is on the left. On my Clockwork that still has a front mech I have fitted the remote on the right in between the brake and gear levers but obviously it has to go the top of the bar.
I never stand my bike upside down so never find this a problem.
Posted : 09/05/2013 6:53 am
Ive had to have mine on the right side on top as couldn't get it to fit on underside left hand. My setup is hope brakes on matchmakers with shimano shifters. Ive tried several times to fit on the left but just wont work without having the lever too far away
Posted : 09/05/2013 6:56 am
SRAM shifters is the answer or avid brakes 🙂
I think you can get a matchmaking adapter for the brakes or shifters?
Posted : 09/05/2013 6:58 am
As creamegg I run Hope/Shimano.
If your reverb is an MMX version it should come with a fixing to enable you to bolt direct to SRAM/Avid.
Posted : 09/05/2013 7:04 am
Or go grip shift on the left.
Posted : 09/05/2013 7:11 am
I've set three up for friends with a rh lever upside down on the left although all were running hope tech brakes.
Search the forum and there are pics of a few people who manage it.
It is tight though.
Grip
Reverb
Shifter
Brake
Stem
Posted : 09/05/2013 7:18 am
Shimano shifters and brakes, 2x9, rh reverb on left no problem.
From outside in:
Grip
Shifter, xt, adjusted on clamp
Xt 2012 lever
Reverb
Works well.
Posted : 09/05/2013 7:30 am
 akak
I'm in the same situation as the OP, planning to go back to 2x but I can't see it working on the left as it is currently tucked right under the brake and there will be no space for the gear paddles. I guess it will be okay on the right but completely horizontal to minimise damage risk.
Posted : 09/05/2013 7:39 am
wobbliscott has the answer - gripshift is way better than levers for the front
Posted : 09/05/2013 8:06 am
 br
Wider bars?
But, I use the Hope/Shimano matchmaker setup.
Posted : 09/05/2013 8:10 am
From Left to Right on my Solaris
GRIP | BRAKE | SHIFTER | REVERB | POPLOC ] [[b]STEM[/b]] [ SHIFTER |BRAKE | GRIP
I run 762mm bars and have largish hands.
TBH its far from ideal.
I'm looking at 1x10 and dropping the poploc so we'll see 😛
Posted : 09/05/2013 8:18 am
 ndg
This is why I've gone with a LEV for my yet to be built bike - lever replaces the inner ODI lock ring - very neat, and one of the biggest selling points IMHO (along with the stationary cable).
Posted : 09/05/2013 8:31 am
On my 1x10 I run a RH lever upside down on the left.
For my 2x10, I wanted it in the same place, but couldn't quite get it. With i-spec shifters, I have it a bit further inboard (this is the closest that it can be to clear the shifter) - it is a bit more of a stretch than on my 1x, but still very reachable.
Dave
Posted : 09/05/2013 8:46 am
2 X 9 and reverb switch mounted upside down on the left like Alfabus above.
On 2 bikes, one previously with Hope mono mini, but now shimano Deore brakes & XT 9 speed shfiter. Other with XT brakes and shifters, no I spec, M775 brakes. Both 711mm bars.
Sure the reverb switch is a little inboard but I can easily move my left hand in a bit to press it. I'm not racing and don't think I have to press it as easily as I do the brake or shifter.
Hands are not big - a M or L glove size and I have a dodgy pair of thumbs as well as they have both been broken !
Posted : 09/05/2013 9:38 am
What's wrong with gripshift then? It seems to be the ideal solution, but nobody is using it.
Posted : 09/05/2013 10:03 am
I don't know about "Ideal" not everyone get's on with Grip-shifters, and some people are fussier about symmetry, plus you either end up looking for a stumpy lock on or a chopped down one (assuming that all sane people us Loc-ons now).
I'd still certainly consider a LH Gripshift if I was looking to accommodate another lever on the LH side of the bars (In fact I think I might have an old on in the spares tub), Question are there any 10spd (Dynasys) compatible Gripshifters about?
I know there's a slight difference to cable pull from 9-10 speed for the front mechs that most can live with, but could you end up with rubbing? I suppose having a front mech trim option might be quie nice on a 2xN drive setup...
Posted : 09/05/2013 10:24 am
[url= http://singletrackworld.com/forum/topic/gripshift-and-shimano-10-speed-compatibility ]In fact... [/url]
Posted : 09/05/2013 10:33 am
Thanks for the replies guys , i'll have another go at it tonight.
Posted : 09/05/2013 6:05 pm
