Bar bag on a Jones ...
[Closed] Bar bag on a Jones H bar? Any ideas for fitting?
[#6260391]
Any ideas welcome: about to go do some off road touring and want to fit an ortlieb bar bag to the front. The standard fitting hangs over the stem to stop it rotating under the load of the bag, but that's not going to work with the H bar (full loop type). Anyone seen a way of doing that or have any good ideas? Thanks
Posted : 10/06/2014 6:12 pm
 Chew
Ask Beth at [url= http://www.wildcatgear.co.uk/ ]Wildcat Gear[/url]. There is a Jones Bar bag in the offing, just not sure if its ready for production yet.
Posted : 10/06/2014 6:19 pm
I guess you could fit a short stem to the outer loop for the wire to wrap around?
Cheers guys..Richpips -think you have something there. Something like a tri bar clamp on the loop might be the answer. Thanks.
Posted : 10/06/2014 8:30 pm
[url= https://farm3.staticflickr.com/2183/5695794498_bc8db71bb4_z.jp g" target="_blank">https://farm3.staticflickr.com/2183/5695794498_bc8db71bb4_z.jp g"/> [/img][/url][url= https://flic.kr/p/9Fjrgq ]2011_0507wildcat0002[/url] by [url= https://www.flickr.com/people// ]multispeedstu[/url], on Flickr
[url= https://farm6.staticflickr.com/5142/5695793274_7ff9f8c20b_z.jp g" target="_blank">https://farm6.staticflickr.com/5142/5695793274_7ff9f8c20b_z.jp g"/> [/img][/url][url= https://flic.kr/p/9FjqUj ]2011_0507wildcat0001[/url] by [url= https://www.flickr.com/people// ]multispeedstu[/url], on Flickr
Posted : 10/06/2014 8:36 pm
A trad bar bag fitted to the front loop will put the weight a fair way out front? Can't see it doing the handling much good or staying put off-road unless done up really tight.
Posted : 10/06/2014 9:03 pm
[img] https://www.flickr.com/photos/45689323@N00/14019366267/ ][img] https://farm3.staticflickr.com/2937/14019366267_7f1a260e1b_n.jp g" target="_blank">https://www.flickr.com/photos/45689323@N00/14019366267/ ][img] https://farm3.staticflickr.com/2937/14019366267_7f1a260e1b_n.jp g"/> [/img][/url] [url= https://www.flickr.com/photos/45689323@N00/14019366267/ ]ECR[/url] by [url= https://www.flickr.com/people/45689323@N00/ ]Steve J Makin[/url], on Flickr[/img]
SJS cycles T bar will allow the Ortlieb to be fitted, however I've no idea if it will be allow it to be opened ?
Posted : 10/06/2014 9:11 pm
and I've seen photos of an additional stem added to the front of the Jones loop (but pointing backwards into the empty spave) that allows the cable to perform its function but strikes me that the bag will be too far forward and be unwieldy
Posted : 10/06/2014 9:15 pm
http://justrollingby.com/the-surly-ogre/
Posted : 10/06/2014 9:17 pm
[img] ?w=804&h=584[/img]
From Steve's link .. also a useful idea for a Garmin etc.
One of the comments at the bottom is positive about the loop/t-bar/ortlieb combo using an extension block.
Posted : 10/06/2014 9:22 pm
If I wanted to mount the bag on the front loop, I'd just use a longer bit of cable (brake cable) and loop it under the stem as it was designed to. But I echo the comments above about the distance in-front of the steerer that it is. I think I'd prefer the accessory mount idea. Or another stem and some old bars cut down to 10cm long.
Posted : 10/06/2014 9:27 pm
Yeah, hadn't thought about handling. It's for some long distance rough stuff touring so I will opt for some old brahma bars instead to get a different choice of hand position.
Posted : 11/06/2014 6:55 pm
