Avid juicy question
[Closed] Avid juicy question
[#856931]
having stupidly buying a set of juicy 3's off the classifides without noticing they came with neither rotors, addapters, or any bolts. I'm shoping arround for the bits.
Do I need the extra alignment washers, or can I fit them without them?
Does anyone have front and rear 160mm rotors, addapters and bolts/wahsers?
Posted : 10/09/2009 3:29 pm
you need the alignment washers if you want your wheels to go around and then stop when you apply the brakes. All availiable on crc. Ebay or on here for cheap rotors.
Posted : 10/09/2009 3:40 pm
 cp
yep, you need the alignment washers to pack out the caliper to make it the post-mount standard size.
Posted : 10/09/2009 3:48 pm
£50, so effectively the new price off merlin by the time I've shelled out for everything 🙁
are the washers the same size as the ones that come with v-brakes? I've got crates of those!
Posted : 10/09/2009 4:01 pm
^^ yes they are
Posted : 10/09/2009 9:52 pm
