I've somehow* managed to strip the thread in the cleat plate in my Defrosters.
(* hamfisted ****tery)
As a result my cleat is now held on by one good bolt and the other is finger tight only.
Where can i get a new plate from? And second, the inside of the boot beneath the insole seems to be a sewn in silver foil type material, is my only option to slice the footbed to get at the cleat plate?
I also am aware there's a second set of holes in the cleat plate, but one of these has the remnants of another bolt in that's had the head drilled off already which i can't get at without getting the cleat plate out anyway. And it wasn't me that did it, this was a prior owner issue!!
If you cut the lining out they won't be waterproof anymore.
Could you epoxy a bolt in? It'd almost definately hold, but would be the last cleat you ever install to them. But at least you'd get one more winter from them.
get a new plate, shimano sell them or use to.
retap to the hole,
tape over the lining.
