Arrgggghhhh: Fettli...
[Closed] Arrgggghhhh: Fettling eff-up
[#7084617]
Is there anyway to save a non-driveside Zee crank with a stripped bolt? If not, can I buy a spare crank? I've done a quick search in the usual places and can't find any yet.
Posted : 22/05/2015 9:41 pm
Nut and bolt.
Posted : 22/05/2015 9:49 pm
Step 1 - Use a hammer
Step 2 - If Step 1 fails, use a bigger hammer
Posted : 22/05/2015 9:50 pm
Perhaps I should expand: Whilst re-fitting the non-driveside crank one of the pinch bolts managed to strip the internal thread of the crank (note that I am blaming the bolt, not myself :mrgreen: ), so now the bolt just continues turning.
A nut and bolt could be an option, if I could find a bolt small enough.
Posted : 22/05/2015 9:55 pm
How about drilling & re-tapping the thread and use a slightly larger bolt?
Posted : 22/05/2015 9:58 pm
Helicoil it
Posted : 22/05/2015 10:02 pm
+2 for helicoil.
Posted : 22/05/2015 10:04 pm
I don't really have the tools for that at the moment but it's an option. If the crank material is that soft, wouldn't making the hole larger weaken them?
 P20
Is there any thread left that a longer bolt would be able to work?
Posted : 22/05/2015 10:05 pm
Chase the thread out with the same size tap.
Some times they will come back, a new bolt can help.
Posted : 22/05/2015 10:09 pm
Madison stock LH Zee crankarms @ £44.99 - pretty much any bike shop will be able to get you one.
Posted : 22/05/2015 10:13 pm
No idea without looking at one TBH. Either helicoiling or buying a new arm would be a better bet if you don't have the kit and aren't in too much of a rush.
Posted : 22/05/2015 10:18 pm
This is going to sound pretty stupid but i have repaired similar by wrapping the bolt thread with strips of tinfoil then seeing if it will bite, sometimes it takes a few wraps/attempts but when/if it does then it's bodgetastic celebration time.
edit : no grease, clean everything so it's squeaky clean and can cause friction>heat between the alloy//foil/bolt when tightened.
OK, cheers folks. I think I will first see if I can get hold of a replacement crank arm. If that doesn't work out then I'll give some of those suggestions a whirl.
Posted : 22/05/2015 10:23 pm
I've had a couple of SLX bolts snap (on different cranksets) and have merrily continued with the one - now replaced with decent bolts.
Posted : 22/05/2015 10:31 pm
ifyoure lakesish I'll tap it. frickin love tapping stuff its like magic
Posted : 22/05/2015 10:41 pm
Fraid not, I'm down sarff, but thanks for the offer.
Posted : 22/05/2015 10:47 pm
My lbs got me a nds 105 crankarm for £22.50. I'd if be shocked if it costs more than £30. Use it as a tin foil experiment first.
Posted : 22/05/2015 10:52 pm
Go see an engineering shop armed with some beer tomorrow morning bet they'll helicoil for you
Posted : 22/05/2015 10:55 pm
FWIW: Helicoils make a stronger, more robust thread than the orignal tapped alloy.
Posted : 22/05/2015 11:43 pm
If you're ever passing Bolton I'd happily helicoil it for you.
Posted : 23/05/2015 7:57 am
If your in lowestoft area pop in and I'll helicoil it for you dude just bring donuts or post it and I'll do it if your not
Posted : 23/05/2015 8:51 am
Dammit you're lucky. I bought a tap and die set and I've been itching to use it but the opportunity hasn't arisen yet.
Posted : 23/05/2015 10:23 am
Green Threadlock.
Posted : 23/05/2015 11:02 am
Superficial - Member
Genuinely lol at this
Posted : 23/05/2015 11:39 am
Where down south are you? If your near Hemel I can re tap it for you..
Posted : 23/05/2015 11:46 am
Thanks for the offer but I'm on the opposite side of London to you.
Posted : 23/05/2015 6:09 pm
 igm
I have an XT nds crank arm somewhere after I broke the spindle thereby trashing the drive side.
Any use?
Posted : 23/05/2015 7:49 pm
I really appreciate the offer but I'd rather pursue a matching arm to begin with. Hold that thought because I may get back to you if nothing else succeeds.
Posted : 23/05/2015 7:58 pm
