Armband HRM and And...
Armband HRM and Android app recommendations
[#12765928]
Is the Polar OH_1 still the go-to armband HRM strap?
And what is a simple reliable Android app to go with it? I want to be able to set up audible heart rate zone alerts, be able to tap the screen to leave a marker on the record and look at my efforts afterwards.
One other question, can Bluetooth cope with two devices at once? (Headphones and HRM).
Thanks in advance
Posted : 23/03/2023 11:50 am
The OH1 has been superseded by the Polar Verity. Looks much the same but has dual channel Bluetooth as well as ANT+
Can't help with the app, I use my OH1 with a bike computer.
Posted : 23/03/2023 11:57 am
Bump for the evening crowd
Posted : 23/03/2023 8:44 pm
Is there a decent android app that does that? Polar Beat is ok - shows heart rate zones, but don't think you can do alarms or lap markers. Strava proibably does something similar, but no lap markers as far as i am aware.
You might need to get a watch or computer that has the functionality you are looking for.
Is there a reason you're going for an optical HR strap? If you are wearing a strap you'll prob get better reliability from an H10 chest monitor
Posted : 23/03/2023 10:03 pm
If you are wearing a strap you’ll prob get better reliability from an H10 chest monitor
Depends on your definition of reliability. Are you talking about reliable as in "won't fall apart`" or reliable as in "always gives the right HR"?
The OH1 I use has been fine on both counts but then as a lowly recreational cyclist I don't make massive demands on it.
Posted : 24/03/2023 12:32 pm
Polar verity sense is great. I had OH1 but it failed and replaced with verity sense.
The battery life is much better and it can connect with 2 Bluetooth devices at the same time, as well as ant+ for Garmin.
The polar flow app that goes with it works well. I tend to use the hrm ‘offline’ for swimming which is much better than using a watch as it’s out of the way on my goggles.
It also works in ‘odd’ ways - have used it before held on with physio tape so it wouldn’t pull off in a swim run race.
If I lost it I would buy another straight away.
Posted : 24/03/2023 12:38 pm
A comfortable reliable "good enough" beats the discomfort I get from chest straps.
My training goal is "a bit less crap" rather than setting any records.
Thanks for the input so far folks.
Posted : 24/03/2023 12:41 pm
I use one of these: https://www.amazon.co.uk/CYCPLUS-Monitor-Armband-Bluetooth-Sensor/dp/B081RMN29P
quite a bit less expensive than the polar one. For me it's decent, consistent, and fairly robust. holds charge for a decent time (I've not found out how long yet).
before that I had one of these: https://www.amazon.co.uk/TwoNav-Fitcare-Accessories-Adult-Unisex/dp/B08DCH8PBG but lost it.
the cycplus one seems to read a few bpm higher than the other, but I couldn't say which was closer to real. it's close enough for me to use as a side by side comparison so works fine.
ANT and bluetooth.
Posted : 24/03/2023 3:03 pm
