Are you running 120...
[Closed] Are you running 120mm frame with 140mm forks?
[#6615554]
if so, what frame?
how is it?
got a hardtail i want to swap the frame out for and an fs but an older/cheaper one. things like a hemlock come to mind. or an older trance.
forks are pike 454 u-turns
Posted : 07/11/2014 10:06 am
No but I am running a 140mm Stumpjumper fsr frame with 160mm Lyriks. Its ace.
Your forks are u-turn so dont worry about it. if 140 doesnt feel right just run the forks at 120. it wont harm the way they work.
Posted : 07/11/2014 10:20 am
well aye, that's part of the reason i want ot try it
Posted : 07/11/2014 10:23 am
i've got a Da Bomb Da Pukka with 140mm at the rear and a 170mm Bomber 55CR up front
its a bit of a bitch going uphill but going down its awesome!! 😆
Running a 120mm Kona frame with 130mm forks - works fine, if anything glad it's made it a bit less twitchy on the steep stuff
Running 100mm Superlight frame with 120mm fork. Its fine, rides a bit better.
20mm is about 1 degree of HA. So noticeable but not likely to radically alter the ride and handling
Posted : 07/11/2014 10:25 am
So if it feels a but slack and vague then wind the fork down a little bit
You'll be grand, no one will die
Posted : 07/11/2014 10:26 am
thanks all, not worried about whether it'll work. fairly sure of that.
more looking for frame reccomendations for that combo.
Posted : 07/11/2014 10:27 am
140mm Pike on a 125mm Turner Sultan here. Rides smashing, slackens it out a bit which is a bonus. 51mm offset forks to help it turn.
Posted : 07/11/2014 10:30 am
Well 2 pople on here will tell you a merida transmission LRS (120mm travel) with 150mm forks on is the awesome.
Mind you I used to ride 100mm blur with 150mm forks too!
Posted : 07/11/2014 10:31 am
Trance X would be good.
Had an older 100mm Trance and 140mm forks made the BB too high I thought, considering it was a short bike anyway.
Maybe get a angle adjust headset or offset bushes too?
Posted : 07/11/2014 10:33 am
What's your budget anyway? Some quite new FS frames are cheap now due to wheel size inflation.
Posted : 07/11/2014 10:39 am
Oddly enough I run a 100mm Trance with 140mm a revelation . Running them at about 30% sag . 760mm bar 70mm stem.
I did have to adapt my riding to get up steeps without the front wheel lofting, no bad thing really, it taught me to climb better I think, a few tweeks to stem and saddle position in a layback dropper post and all is good.
Frankly for me it's transformed it into a bike which I really like as opposed to the one I bought and worked out how it needed upgrading to suit me.
In my case , the slightly raised bb seems to have reduced pedal strikes. Either that, or just maybe, I've become a slightly less rubbish rider !
Posted : 07/11/2014 10:43 am
not quite new frame sized is my budget. also not for right now, need to sell some stuff first..
am hoping it will be under £200
Posted : 07/11/2014 10:45 am
I'm running a 120mm Boardman FS with a 140mm Revelation. Seems to work nicely, but the front can be a bit vague on the steep climbs
Posted : 07/11/2014 10:47 am
Yep, I'm running a Spesh Camber with Rockshox Revelations, wound down to 135mm travel, which seems to be the sweet spot.
Posted : 07/11/2014 10:59 am
2009 FSRxc - originally 120mm F&R
Now - 160mm Lyrik up front and a 200x57mm shock at back giving 152mm (I think - original 120mm was with 185x45mm).
Running offset bushes to slacked it out a bit, and it also reduces the length of the shock a bit. Descends far better now, A bit more work on the uphills but with the added bonus of fewer pedal strikes on rocks and roots now.
And now I know it works, I can be on the save for a CCBD Inline.
Posted : 07/11/2014 11:07 am
 FOG
Not yet but as soon as I have some spare cash I am putting some 140s on the 29er Trance which currently has 120mm in a desperate attempt to cut pedal strikes. I realise it will be a bit of a trade off when climbing. The front wheel will presumably lift more but I am hoping not to grind to a halt on technical rutted climbs when it becomes impossible to turn the pedals.
My last FS came with 100mm forks which I increased to 120 with only beneficial effects, in fact I think it would have taken 140 with little problem
Posted : 07/11/2014 11:23 am
140mm Pikes on a Dialled Prince Albert here (which is aimed at 120-140mm)
It's boss...
Posted : 07/11/2014 12:02 pm
they're making FS prince alberts now? 😀
Posted : 07/11/2014 12:38 pm
Me too,bought mine as a frame & ran it with 130mm U-turn Revs from the off,loved it !Tried it with the forks wound down to 100 & it rode terrible TBH..
Posted : 07/11/2014 12:42 pm
so what year(s) are the 100mm trance frames from?
Posted : 07/11/2014 1:10 pm
140 on an old 120 stumpy, quite honestly couldn't feel the difference.
Posted : 07/11/2014 1:12 pm
Alltricks have cheap Santa Cruz nickels that would work with 140-150mm forks. Got a 125mm solo with 140mm forks and it's a great combination, bit limited on proper dh tracks but still doable. Spot on for everything else
Posted : 07/11/2014 3:02 pm
hmm, 800 quid is a bit more than under 200, but thanks anyway!
Posted : 07/11/2014 4:12 pm
My Trance is a 2008. Same basic shape as the 2009 trance x 120mm ,
Still on its original air can , cranks and ( believe it or not, 5000 miles later) avid Juicy brakes, got quite "good" at keeping those bled and working well !
EDIT: please note for " good" read: Stubborn and skint.
Posted : 07/11/2014 4:23 pm
Mine's a 2007-They were originally 100mm(the ones with the "glory hole",where the shock sat) & then changed to the bendy down tube 2009ish to 120mm..The frame's as tough as old boots as well
Posted : 07/11/2014 4:28 pm
I used to run an Idrive 5 (130mm) with 140mm forks (new owner ran it with 150) and a Camber (120mm) with 130mm of forks- both performed much better with "too much" fork, like they were designed for it.
And ironically I put 130mm of travel in a Scandal that was designed for 100-130mm, and it rode like a bag of shit till I went back to the normal 100mm 😉
Since you mentioned a Hemlock, the 2nd gen works best with 160mm of fork imo- I ran mine with 140mm for about a week, didn't like it. Lyrik'd it and it all made sense
Posted : 07/11/2014 4:35 pm
 Kit
140mm Revs on 120mm ASR-5. Bit tricky on steep uphills, but otherwise feels nice.
[url= https://farm4.staticflickr.com/3730/13881506265_f2250ba7fc_z.jp g" target="_blank">https://farm4.staticflickr.com/3730/13881506265_f2250ba7fc_z.jp g"/> [/img][/url]
Posted : 07/11/2014 4:39 pm
so you rn the hemlock at 120 160 northwind?
beast
Posted : 09/11/2014 2:19 pm
140 revs on a 120 trance.
Bb unsagged is 345mm according to a bike geo calc, which is plenty low. 68.5 ha.
even that feels a little steep.
Posted : 09/11/2014 3:37 pm
jamiesilo - Member
And a works slackener headset. Climbs like a bag of shite, I must admit but goes back down rather well.
Posted : 10/11/2014 8:29 pm
