are sram powerlinks...
[Closed] are sram powerlinks directional?
[#3296395]
Anyone know if there is a correct way round to install a 9 speed sram power link, are they directional like the wippermann connex links?
Thanks
Posted : 30/10/2011 7:21 pm
No
Posted : 30/10/2011 7:23 pm
No.
yes!
nahhh not really...
Thanks,that means I need to look for another reason why my chain skips on the 11 tooth cassette cog.
Brand new chain and a 150 mile old cassette,so hopefully not a worn cassette problem
Posted : 30/10/2011 7:25 pm
Yeah, line up the blue dot with the red one.
Posted : 30/10/2011 7:26 pm
No but HDMI cables are.
Posted : 30/10/2011 7:28 pm
If you use the 11t a lot you could knacker it in 150 miles.
Posted : 30/10/2011 7:31 pm
Check your rear mech setup...
Likely causes are
bent hanger
bent mech
incorrect cable tension
badly adjusted limit screw
wheel not seated in the drop out properly
freehub wobbling/loose
old cables sticking
gremlins (it's nearly halloween)
Posted : 30/10/2011 7:47 pm
I had this with a new chain today. 'twas fixed by twiddling the limit screw. Can't fathom why changing the chain would affect this, but it did.
Posted : 30/10/2011 7:51 pm
Will get it on the stand tomorrow and have a close look.
Posted : 30/10/2011 7:55 pm
