Anywhere for bespok...
[Closed] Anywhere for bespoke OS maps?
[#723992]
I am looking to do a long road ride in a few weeks time but the areas i want to cover are on 4 different OS Landranger maps. Short of buying all 4 and carring them with me, is there anywhere where i can order or make up a bespoke map that will cover all the areas that i want?
For smaller areas i have printed out bits from multimap and stuck them together but not really wanting to do that for a large area that covers 70miles from south west tip to north east tip of the route.
Is there such a place that provides this service or is it a case of sticking bits of paper together again?
Posted : 21/07/2009 11:43 am
road atlas page? 99p from the works & tear out the page
Posted : 21/07/2009 11:45 am
 wors
yes ordnance survey site. 😀
OS offer a service called OS select where you can select the centre point of a map, they do it in Explorer and Landranger ranges.
[url= http://leisure.ordnancesurvey.co.uk/osselect ]OS Select[/url]
that might cut it down to 2 maps I guess.
Posted : 21/07/2009 11:47 am
Very expensive IIRC. You pay a certain amount for every square Km. I looked into getting some and was quoted £130
 TomB
The bespoke OS map is only about £15, I've got one on my wall, centred at my house!
Posted : 21/07/2009 11:50 am
Try [url= http://www.mapyx.com ]Here??[/url]
Posted : 21/07/2009 11:51 am
Tracklogs let you pick a spot and get the mapping around it. For road 1:50k would do fine, 60km square is £12, up to 100km square for £33.
You could then get it printed - if you plot your route on there first then you could just generate a PDF of A4 pages which you could take down to the print shop for colour laser print (in case they get wet). Would probably fit in a jersey pocket better too.
[url] http://www.tracklogs.co.uk [/url]
Posted : 21/07/2009 11:52 am
 anjs
I have used Aqua maps in the past http://www.aqua3.com/
Posted : 21/07/2009 11:54 am
TJ I think you are talking about GPS maps like the Satmap system. As hp_source says, OS Select sounds like what you need.
If you're just riding on the road you could even go to a larger scale. I've used [url= http://leisure.ordnancesurvey.co.uk/products/paper-maps/paper-maps-ordnance-survey-great-britain/paper-maps-ordnance-survey-great-britain-os-travel-map-road ]these[/url] when touring on the road with no problems.
Posted : 21/07/2009 11:55 am
if you let me know the route you are doing i can print off some A4 sheets from Memory map for you covering the relevant bits of your route and you can just take these with you.
I dont have the fancy waterproof paper that you can get though so dont get them wet or fold them up and stick them in a freezer bag in your back pocket or something.
Email me your route and i'll try do it tomorrow.
Posted : 21/07/2009 12:06 pm
Mr Agreeable - it was definatly OS mapping - it however has changed a few times over the years as to how they price it up.
Posted : 21/07/2009 12:09 pm
