Anyone use gaiters ...
[Closed] Anyone use gaiters and boots in winter??
 ton
[#2201286]
for riding.
a good set of goretex walking boots and a set of gaiters seems like a good solution to everyones 'what winter boot' question.
no?
Posted : 18/11/2010 4:53 pm
When it was snowy I used leather walking boots just to keep warm and dry. The pedal grip wasn't great though because of the hard rubber soles and chunky cleats. And in snow drifts the snow got in. So I then wore gaiters to, and it was cosy.
Posted : 18/11/2010 4:59 pm
Shimano do some 'spd walking boots' that might fit the bill?
Posted : 18/11/2010 5:00 pm
 ton
in theory, you could use a 5/10 type shoe with a waterproof sock and gaiters...........perfect solution.
Posted : 18/11/2010 5:01 pm
Are there any gaitors that do not have an under-heel strap?
Posted : 18/11/2010 5:02 pm
One of my riding buddies turned up in some gaitors over his normal spd boots a couple of weeks back - he had warm, dry legs and feet! Been looking at neoprene ones online....just to reduce the 'baggyness'...
Posted : 18/11/2010 5:04 pm
Mate of mine uses the Shimano "SPD walking boots" as mentioned above, plus some cordura ankle gaiters to keep the crud out. Seems to do the job.
Also, the redsocks see him as one of their own, so he gets pushed to the front whenever some diplomacy seems in order 🙂
Posted : 18/11/2010 5:06 pm
Gortex walking boots reshod with 5-10 stelth ruber and sealskin socks works for me
Posted : 18/11/2010 5:07 pm
I made up some gaiters last year out of off cuts of neoprene I had laying about. They run from mid-calf to the top of my Shimano winter boots and do a great job of keeping the water out even in the wettest conditions.
Posted : 18/11/2010 5:10 pm
elliptic: I thought I saw you'd gaffer-taped your sealskins to your legs!?
Posted : 18/11/2010 6:05 pm
I used gaiters in the snow - worked fine. SPD shoes on tho.
Use shimano mw80s with gaitors and waterproof trousers.
Posted : 18/11/2010 6:11 pm
Buzz - yup, done that 🙂
The trick is to use rubbish duct tape from a pound shop or somewhere - it hurts less when you peel it off...
Posted : 18/11/2010 6:39 pm
Not walking boots but I put [url= http://www.inov-8.com/Products-Detail.asp?PG=PG5&L=26&P=5050973025 ]Inov8 gaiters[/url] over the top of Northwave boots.
Posted : 18/11/2010 8:50 pm
I use like this
http://www.surplusandoutdoors.com/shop/outdoor-clothing/waterproof-clothing/new-british-army-knee-length-505294.html
but slightly more trendy. The ones I have, have a little slit at top and a vecro pull fit strap, totally waterproof thin enough to wear with normal socks, well over calf length so with long shorts you're covered.
Hunting/fishing/shooting shop somewhere.
Posted : 18/11/2010 9:06 pm
Used to use '[url= http://www.simplyhike.co.uk/products/Berghaus/YetiExtremGaiter.aspx ]Yeti[/url]' gaiters yonks ago with Scarpa boots whilst stomping all over the moors...brills.
TBH I'm amazed that the industry giants haven't produced a similar sole? The Scarpa has(d) a cut-out, approx. 4mm deep by 3 width, that the rand on the Yeti gaiter beds into + the under-sole fore-foot of the gaiter has a band that slots into a similar rung within the tread.
All you'd need then is nice Mr Gore to market a sexy pair of pac-lite gaiters....sorted.
Posted : 18/11/2010 9:08 pm
I've used Berghaus goretex walking boots (with waterproof trousers when it is wet) for ages during the harsher winter days. Works for me.
Posted : 19/11/2010 10:16 am
I wear hiking boots most of the winter. If it's lashing it down I'll have waterproof trousers on, but at other times I'm not sure gaiters would give much additional benefit, my boots are fairly high. In the snow last year I was wearing my B2 rated boots for biking 🙂
Posted : 19/11/2010 10:22 am
In the snow last year I used some cheap (£7 from tesco) ankle gaiters over the top of my MT91s, with waterproof overtrousers over the top. Worked a treat.
And don't use shimano SPDs in snow - rubbish. Time Z controls worked fine, but I'm getting some flat pedals for this winter.
Posted : 19/11/2010 10:41 am
Tracey - this sounds a great idea. Where did you get it done, and for how much?
Posted : 19/11/2010 12:16 pm
I used to ride with a guy who rode in gaiters on summer as he didn't like the brambles and nettles bashing his exposed shins. made sense but looked stupid. I guess it would work for winter riding, surprised no one makes winter riding trousers with waterproof lowers!
Posted : 19/11/2010 12:35 pm
You could maybe look at trousers designed for ski touring? I've used mine in the winter for biking. Mine are a sort-of lightweight soft shell material with waterproof fabric from the knee down. They also are double fabric at the bottom so one can go inside your boot/sock and the outer layer over. Some brands are quite narrow around the ankle.
Posted : 19/11/2010 2:48 pm
