Anyone had any sucess with servicing these? Is there a guide somewhere?
I've a suspect time MX2 Pedal. I've taken the outer bearing cover off and removed the nut but cant get the Axle out. Is there a trick with these? The bearing itself I think is fine but the bushing on the inside is pretty wobbly and suspect so wanted to have a look.
Posted : 25/06/2018 9:55 pm
Tap it with a hammer, pops right out. I used a punch to get in at the axle end.
Posted : 25/06/2018 10:47 pm
I threaded the nut back on partially and gave that a whack with the socket end on. Didn't seem to budge. Will try your method. Perhaps I'm just not hitting it hard enough 🙂
Posted : 25/06/2018 11:40 pm
