Anyone riding a can...
[Closed] Anyone riding a cannondale prophet?
[#5129024]
Noticed frames going cheap.are they any good?on par with stumpjumper or reign?
Posted : 04/05/2013 10:52 pm
Cracking bikes, one of the first to crack the slack head/ steep seat angle geometry to give you something that climbed well and descended well.
I've just sold my MX, various minor reasons. I'd not have changed but I picked up an ex demo Cotic Rocket frame that is an amazing ride. I was looking elsewhere as I am slightly between sizes on 'dales so the med I had was a fraction small but large was well too big. That, plus the Prophet was never going to be RS Reverb compatibile and dropper seatposts are very much in my future, made me Rocket-curious and now I have it there is no room for Prophet as well.
I'd urge you to try one - if you don't like it then you can almost certainly move it on for what it cost you - but they are great bikes. I've had a lot of good times on mine.
Posted : 04/05/2013 10:59 pm
bit long in the tooth, but i like it, good all rounder, get the MX version if you can.
ps gravity dropper 😉
Posted : 04/05/2013 11:02 pm
My mate Simon loves his.
Posted : 04/05/2013 11:03 pm
Thanks for reply seen em going for around £300 frame only I was thinkin stumpy but too rich for my blood at the mo but you say not compatible with a remote seat post,that is a shame I've fancied one for a while maybe not then ??any other alternatives around the same price bracket?
Posted : 04/05/2013 11:05 pm
Very heavy?,compared to say a stumpy or heckler
Posted : 04/05/2013 11:07 pm
Love mine, had it 4 years now and see no reason to swap it.
27.2mm seat tube is not a problem as I'm using a Gravity Dropper, which is simple and low maintenance - just like the Prophet's single pivot suspension (still on its original bearings). Great angles, 1.5 head tube so you can use a wide variety of forks.
Never ridden either but Stumpy will be lighter and the Reign heavier.
Posted : 04/05/2013 11:08 pm
What about sizes fellas I'm 5.9 with little T. rex arms medium?small?
Posted : 04/05/2013 11:13 pm
I'm 5'9", of normal proportions and ride a medium.
Posted : 04/05/2013 11:17 pm
And here it is......
Posted : 04/05/2013 11:22 pm
The frame design gets a bad rap,I like it. Thats nice.more pics please folks
Posted : 04/05/2013 11:26 pm
Yep, I've got one, they're amazing value for money. I picked my (none MX) frame with headset front mech and RP23 for £280 back in August I think. Can't fault it, they have somewhat of a bad rep due too possible crackage, but right now, mine seems fine... I can't really complain, love the design, the choice of slack & single pivot simpleness, seems a bargain all rounder, I wouldn't choose anything else (for the money I spent) over this again. I very nearly got an older stumpy with one of the older floats. Pretty glad I didnt!
Posted : 05/05/2013 12:17 am
What I had in my hands but never really bought...
Posted : 05/05/2013 12:22 am
Had one for ages great do it all bike simple to maintain and with the lefty max not much maintaining to do.
Posted : 05/05/2013 6:23 am
I built one up to ride as a winter bike a few years ago, to save my s-work stumpy.
1x10, g-dropper etc...
It became my go to bike.
I stripped it last summer to build a covert, but built it up again in the autum, and again it became the bike I wanted to ride.
I use 150mm forks and the slackest setting which is 67.5.
The only slightly annoying feature is the seat tube which means you're stuck with a GD dropper, which I don't like when compared to a reverb.
Building a five now, so it will be really interesting to see how they compare.
I saw a post where someone had 650b wheels on theirs, could be interesting.
I'm going to hold onto my frame.
So in sort, I really rate them , great value frames. The did a shorter travel version 120mm as apposed to the normal 140mm.
You can pick up full bikes for between £600-£800.
Posted : 05/05/2013 7:00 am
I did wonder about the 650B wheels, but they only work in the XC geo setting, bugger that. The 120 SL's only difference was a shorter shock, same frame & can be even bigger bargains than 'std' one.
Posted : 05/05/2013 7:55 am
I have an SL which has been my only bike for about 6 years. I can see no reason to change it - it's a great machine. I've just upgraded the RP3 to an RP23 which has made a huge difference - the SL had a shorter shock as standard - and the next thing will be to find a Lefty Max 140 as the current fork is a Lefty Speed 110. Find a 27.2 dropper (best thing I've ever bought for any of my bikes) and you're set.
Sizing - I'm just shy of 6' and have a medium - I would try a med and a small to see what works. I come from a DH background so don't like long riding positions - you might be OK with a med and short stem.
Posted : 05/05/2013 8:05 am
I think the 650b option could be interesting, what about that with a 1.5 deg angle set to get the head angle back?
I only rode the bike once with on the XC setting, didn't like it, it felt really high, so I swapped it back quickly.
I've also got a 190x50 shock which might work with those wheels, and be a compromise between the two settings.
Posted : 05/05/2013 8:09 am
Can't use an angleset with a 1.5 steerer or lefty, which are my options, but the shock idea could be worth investigating.
Posted : 05/05/2013 8:47 am
I've actually so far only ever rode mine in XC setting, i'm pretty happy with it like that!
Posted : 05/05/2013 10:15 am
if you use a 190mm x 50 shock the tyre will buzz the seat tower on full compression with a 26"on the dh setting,you may get away with it in the xc mode but it will definitely clash with a 650b.
Posted : 05/05/2013 10:29 am
i did have one by the way and they are great fun bikes, stick a coil shock on it and a pair of 160mm forks,maybe even a pair of 180mm forks and you`ve got a great little mini dh bike. used mine for a couple of years over the surrey hills mainly and loved it!
Posted : 05/05/2013 10:32 am
 Doug
Go well as a do it all bike as you can also run a 200*57 shock in the XC postion with some offset spacers for 160mm travel. Combine this with 160's up front gives about 67deg. Add a second pair of heavy duty wheels and your all set for the uplifts/Alps. Pop the aircan and lighter wheels back for all day goodness.
Sold it once and then bought it back as I missed it so much.
Got a Canyon AL+ at Xmas to replace it which isnt quite as capable but a few lb's lighter as I now also have a dedicated Big Bike. Can't bring myself to part with my frame again as it's got a couple of dents so wouldnt get what it's worth to me.
Posted : 05/05/2013 10:37 am
Love mine. Started life as a Prophet 3 but nothing on it remains as standard. Ran it with Pikes for a while, now 150 DPA Revs. Gravity Dropper obviously 🙂
Posted : 05/05/2013 10:54 am
I think the only original bit on mine is the seastpost clamp, I've changed everything else over the years.
Biggest improvements were swapping the Pike coil 409s for 2012 Dual air Revelations and the Float R shock for an RP23.
Posted : 05/05/2013 11:00 am
AlexD, please try the FR mode, don't limit your enjoyment of this frame by only ever using the XC setting. There a lot of fun
Come on all you Prophet lovers post up some pics!
Posted : 05/05/2013 11:03 am
Ok, ok! No need to nag 😉
[img][url= http://farm8.staticflickr.com/7221/6853947580_155f38fb35.jp g" target="_blank">http://farm8.staticflickr.com/7221/6853947580_155f38fb35.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/86995884@N00/6853947580/ ]IMG_00000025[/url] by [url= http://www.flickr.com/people/86995884@N00/ ]woldspinner[/url], on Flickr[/img]
Posted : 05/05/2013 11:13 am
Being used, not pampered... sorry for the rubbish, non-action photo's but you did ask..
With Lefty
[url= http://farm6.staticflickr.com/5031/7077734509_fa6433c1df.jp g" target="_blank">http://farm6.staticflickr.com/5031/7077734509_fa6433c1df.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/15253377@N00/7077734509/ ]C'dale Prophet[/url] by [url= http://www.flickr.com/people/15253377@N00/ ]z1ppy2[/url], on Flickr
140 Rev's
[url= http://farm6.staticflickr.com/5055/5514375569_c415cb9f35.jp g" target="_blank">http://farm6.staticflickr.com/5055/5514375569_c415cb9f35.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/15253377@N00/5514375569/ ]Bike & barge[/url] by [url= http://www.flickr.com/people/15253377@N00/ ]z1ppy2[/url], on Flickr
It's just a fun bike, lots of ppl have used them as play thing (160mm forks), other like me just enjoy them as great handling fun trail bike
Posted : 05/05/2013 11:16 am
Looks good in black Shifter.
Posted : 05/05/2013 11:19 am
Ta. With added dust:
[img][url= http://farm9.staticflickr.com/8535/8709081793_061e7be987.jp g" target="_blank">http://farm9.staticflickr.com/8535/8709081793_061e7be987.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/86995884@N00/8709081793/ ]DaleatDegla[/url] by [url= http://www.flickr.com/people/86995884@N00/ ]woldspinner[/url], on Flickr[/img]
Posted : 05/05/2013 11:22 am
 kilo
Bought mine cheap of e bay for a winter hack a couple of years ago and kitted it out with cheap kit, bits from the shed and Marzocchi 44 RLO's on the front. Has been a really good buy, even more so since changing from the xc setting.
Cant believe the response, this is a real favourite by the looks of it.I should have kept my mouth shut, the prices may go up now.someone mentioned cracking frames anyone had expetience with cracking on thier frame? I mainly ride trail centre due to being lazy and time constrictions, never dropping more than two feet or so.what set up would you suggest, forks, shock etc.and thanks for replys, great info
Posted : 05/05/2013 11:54 am
i have an manitou isx6 shock and rev 150s with a zero stack headset, corners like a dream, only prob is the trails feel too smooth 😉
Posted : 05/05/2013 12:02 pm
Thats it im on the market in a few weeks, looking for one in black after seeing shifter's but at that price I can afford to powdercoat.are the decals easy to pick up? I want it to look showroom before I build it.
Posted : 05/05/2013 12:30 pm
<braindump>
I've heard of some Cannondales cracking but not a Prophet. In 5 years I haven't needed to change the swing arm bearings but I've been through a few shock mounts. The Cannondale lower headset cup is a big old lump, a Hope reducer fits but you get reduced fork top to down tube clearance. I dumped the standard BB mount front mech for a SLX seat tube mounted double specific mech.
<endbraindump>
Posted : 05/05/2013 1:11 pm
 kilo
I ended up using a token reducer as the big old lump hope reducer seems to be discontinued;
http://www.chainreactioncycles.com/Models.aspx?ModelID=38693
so far so good
Posted : 05/05/2013 1:15 pm
[url= http://singletrackworld.com/forum/topic/cannonfail-happy-if-mis-matched-ending-content ]They can crack[/url] but I've never heard of issue happening much (twice on here IIRC), adn there still a **** loads of them coming and going on ebay.
[url= http://singletrackworld.com/forum/topic/show-me-ya-cannondale-prophets-and ]Old photo thread[/url]
[url= http://singletrackworld.com/forum/tags/prophet ]lots of prophet threads[/url] before tags got taken away from the masses.
As for colour, the raw ones are much better than the 'single' colour frames IMHO of course (don't mention the poo brown one!), but the only colour scheme I've been tempted with otherwise was this:
It just worked so well.
PS: they have a straight 1.5 steerer, so 1.5 or tapered fork bargains are the way ahead.
PS#2: [url= http://www.ebay.co.uk/sch/sis.html;jsessionid=82B5DF5D8F3A86F365DE9283557301EF?_nkw=CANNONDALE%20mountain%20bike%20MTB%20decal%20stickers%20set&_itemId=110445632484#ht_1911wt_958 ]Ebay seller for graphics[/url] (there are probably lots of others)
Posted : 05/05/2013 1:28 pm
I've got a Hope Step Down in mine with the deeper lower cup.
Posted : 05/05/2013 1:33 pm
[url= http://qwertycycles.co.uk ]Qwerty Cycles[/url] are good for hard to find Cannondale bits and pieces.
Posted : 05/05/2013 1:46 pm
Judging by comments you can run with a tapered stearer too? It just keeps getting better,what year did they stop making the prophet and what year was the mx?
Posted : 05/05/2013 2:42 pm
Last "normal" ones were 2009. Don't know what years MXs were sold.
Posted : 05/05/2013 2:44 pm
a link to a pic of my old one which i`ve sadly sold now!
http://www.pinkbike.com/photo/7326052/
Posted : 05/05/2013 2:59 pm
I bought one on a whim a couple of years ago. £230 for frame, hope reducer headset, rp23 shock, xt e type front mech and postage. Utter bargain!
I also ran mine in the slacker setting and really liked the way it handled. I had 3 bike, a light weight carbon rush, steel hard tail and this prophet that I built up cheap. The prophet was always the bike I picked and the other two sat gathering dust.
I think it's pretty light weight and was doing 60k rides on a regular basis while I was training for a marathon.
It deals with rough, rocky and fast terrain really well and soaks up the bumps, where I felt that it was let down was on smoother undulating trails like spooky wood or berm baby berm at glentress, for these trails I just flicked the proposal on. It seemed to wallow a bit (im thinking that this could have been fixed by a custom shock tune) On all other terrain it was great, couldn't fault it.
I had it running rev u turns 120-150 and an x-fusion dropper post.
I stripped it and put everything on a newish cannondale rz120 but I'm thinking of going back to the prophet as it's so much more stable ion the rough stuff. Although I'm not using the prophet right now, I can't bring myself to sell it.
Anyone had their shock push tuned or had custom work done on it?
I think all the mtb mags gave the prophet perfect 10 scores too! If you're thinking of getting one powder coated or painted, think about a raw finish, they look amazing IMO.
Posted : 05/05/2013 6:10 pm
Black is a good look for them 😉
Changed the shock
and my old blue one
Posted : 05/05/2013 8:47 pm
