I'm interested in getting one as a low(ish) price [url= https://www.alpkit.com/products/tivaro-13 ]bar bag[/url].
Anyone got one? Are they good/stable/robust etc?
Is there anything else to consider at around £40?
I see that the Tivaro comes with an integrated harness, but I can't see a picture of what it looks like.
I have an Alpkit Airlock Dual 13L and a Joey harness which is absolutely fine. Probably a few quid cheaper all in to the Tivaro.
The Alpkit airlock dual 13l with the joey harness would be £6 cheaper and do exactly the same thing. Plus you get a choice of colours!
I've used the above setup a few times and it's pretty stable.
Edit too slow!
The airlock dual looks like you can strap it on directly to the bars without the need for the (joey or other) harness - albeit it might be a little less stable. Has anyone tried that?
Is it basically a posh Joey/AirLock combo?
Does the airlock require an extra harness for bar attachment?
The airlock can be strapped directly to the bars, the joey makes it more stable and also stops the airlock rubbing on the frame etc
Thanks ssboggy
Joey is out of stock now. Aargh
