I've got an 8 or so year old one
tried fitting it from daughters 16 inch bike to a 20 inch Hot rock and the U shaped bolts are too short and won't fit around the head tube. Haven't measured it but guess the 16 inch bike has a 1inch head tube, not 1 1/8
have they updated these to fit fatter headtubes? This looks like it shoulf fit?
http://www.ukbikestore.co.uk/product/53/tb01c/trail-gator-extra-receiver-kit.html
thanks
Mine's only a couple of years old, so could measure the bolts when I get home later.
DezB - yeah that would be great
thanks
charlie
Will do - will reply to this.
You could try giving UK Bikestore a ring - unlike some online retailers, they do actually answer their phones!
cheers dez - looks like mine is the same. Suspect my bolts are just a bit bent through use on other bikes - managed to get it on last night (just)
think the issue is that the top and down tubes are pretty beefy and no gap between, so u bolts have to go above top tube and below downtube - not between = tight squeeze. Bolt holes in mounting bit could do with being wider spaced
