Any reason I should...
[Closed] Any reason I shouldn't put my bearings in a deep freeze
[#6278716]
Cartridge bearings for Surly singlespeed hub. Very tight fit, any reason I shouldn't cool them to make them easier to fit?
Posted : 18/06/2014 10:42 am
Not that I can think of.
Posted : 18/06/2014 10:50 am
I thought that was pretty much standard practice. Go for it!
Can also pour boiling water over the hub to warm it a bit if you need to - but much more scald potential there. Also make sure not to get it on other bearings that may still be there as you may wash out grease.
Posted : 18/06/2014 10:52 am
Thanks thought it was OK but as my last set only lasted 50 miles due to my mechanical ineptness I thought I'd check first 🙂
Posted : 18/06/2014 10:54 am
Standard pratice innit.
Bearings overnight in the freezer.
Hub shell 5 minutes in the microwave.
Then simply bash together.
Posted : 18/06/2014 11:02 am
This is an important stage in the process.
Posted : 18/06/2014 11:04 am
I fear 5 minutes is inadequate, I'd go for 45 to be sure. And retire to a safe distance.
Heat gun on the hub shell FTW.
Posted : 18/06/2014 11:08 am
Hub shell in the microwave? Have you seen what happens when you put metal in a microwave?
Posted : 18/06/2014 11:47 am
Agh you see, you can put metal in the microwave if you stand it on an upturned plate!
Frozen Lasagna cooked in the microwave is no longer a problem for you now!
Posted : 18/06/2014 11:49 am
@ Globalti
[img] http://forum.esforces.com/attachment.php?attachmentid=1241&d=1302417948 [/img]
Posted : 18/06/2014 12:03 pm
