Any Cannondale left...
[Closed] Any Cannondale lefty experts in?
[#8450616]
Can anyone shed light on hub compatibility. Will a supermax hub fit the lefty 2.0 fork on a Cannondale Habit 2016
Posted : 11/04/2017 9:38 am
Supermax hub fits Supermax lefty is the fork on the habit a Supermax? Lefty hub fits Supermax fork using a brake adapter, other way won't work.
Posted : 11/04/2017 9:41 am
I don't think so, the 2016 Habit had a normal Left 2.0 hub which is not compatible with the supermax.
Posted : 11/04/2017 9:42 am
Some info here for you.
http://forums.mtbr.com/cannondale/cannondale-supermax-hub-vs-regular-lefty-hub-swappable-946675.html
I use a standard Lefty hub on a Supermax fork with the relevant brake adapter (moves the caliper further in).
Posted : 11/04/2017 9:43 am
The Swedish Chef - Member
Incorrect 🙂
Posted : 11/04/2017 9:44 am
Just looked at the spec lefty 60 hub is fitted to the 2016 habit carbon so looks like your Supermax hub will fit.
Posted : 11/04/2017 9:46 am
interesting, thanks.
Posted : 11/04/2017 9:49 am
Confusing!!
Posted : 11/04/2017 10:15 am
granny_ring you're not wrong!!
Just going to buy the lefty 60 hub to save any mistakes and build up spare front wheel that way
Posted : 11/04/2017 10:28 am
