Anyone else found the seatpost too short on the x4? Believe it's 400mm but the min setting is far too long. Ideas how I can get say 500mm?
.....seatpost too short on the x4....but the min setting is far too long....
Eh ?
I did test ride a large framed Anthem X1, and found that I had to use my own 400mm post, as the original was too short.
But then I felt that I also needed a larger frame... maybe you too?
Cheers. I meant minimum setting too short
I put my Thomson on my small frame X4 so not been a problem - I have a fair bit of post out - 37.5mm post about 25cm out for usual XC duties
your frame doth be too small then surely ?
The minium insert lines on those posts are on the cautious side, you need 100mm of post in the frame to be safe and sure. Of course, riding with it above the max mark would void any warranty. Are you SURE you have the correct sized frame? 😕
