About to try a 2.6 Nobby Nic on a 30mm internal DT EX511 rim to go inside a non-Boost Yari (27.5)
Is that going to work well based on people's experience ?
Will I have to switch back to narrower in the mud ?
Posted : 12/09/2018 2:10 pm
Do you have a mudguard within the arch?
Posted : 12/09/2018 2:19 pm
I run a 2.6 Nobby Nic in 29 flavour in non boost Ohlins fork. The rim is a Sentry. It’s similar size to a 2.35 Magic Mary.
Posted : 12/09/2018 2:51 pm
Thanks, I have a mud guard but I assume I won't be able to run it with the 2.6
Posted : 12/09/2018 9:18 pm
Hmmmm.
I'm hoping to fit a 2.6 magic mary and a mudhugger into my pike.
Posted : 12/09/2018 9:26 pm
I assume the 2.6 MM is bigger than the 2.6 NN in terms of knob protruding so I think you'll struggle
Posted : 12/09/2018 9:31 pm
