I'm confused. I know they haven't gone Charger yet so not airshaft a large Pike, so I'd assume it's still 'all travel' spacers as it always used to be, but any documentation I can find seems to state only up to my2012 or so? I have 2014 & 2015 Revs in 650b chassis with fast black stanchions I'd like to adjust travel on...
Or are they fixed at manufacture and no longer possible to alter?
Ta!
Not sure but if you go to the sram pages you can get the tech docs for the fork and the spare parts catalogue has full exploded drawings which has should show if they are spacers or different parts
For 2015 Solo Air Revs you'll need a new airshaft like this..
http://www.amazon.co.uk/Rock-Revelation-Shaft-Change-Travel/dp/B0199Y9PJY
What size are you going from/to?
From 150 to something like 130ish is the mot pressing... Is that a similar part to the £30 air shafts on the Pike then?
Aha. Thanks guys! Seen the doc now. Different to how it used to was, but still very doable.
Ta! 🙂
Vincieup, do you have a link to the docs, I'm keen to do this myself.
