AirDrop edit brake ...
AirDrop edit brake routing
[#13535595]
Afternoon all,
I’m building up an Edit MX but not sure about rear brake routing. Is it along the chainstay then over the BB an under the main pivot?
Posted : 18/05/2026 2:25 pm
Inside the chain stay (bolt with a hose clamp) and under the main pivot it slide into the frame.
Posted : 18/05/2026 2:57 pm
Mine runs down the drive side of the down tube, between the two shock mounting plates, over the bottom bracket shell and into the grove under the chainstay yoke.  Fully compress the rear shock to set the hose length at full travel.  It takes more than you might think if you just eyeball it.
Posted : 18/05/2026 4:07 pm
The funny thing is I've got one and I have no idea what the hose routing looks like from memory.
If I was at home I'd post some pictures.
Posted : 18/05/2026 4:10 pm
https://ibb.co/60Kpg0RD
That's a pic of mine.
Posted : 18/05/2026 4:22 pm
Perfect, thanks all
Posted : 21/05/2026 2:07 pm
