Hello used search and found htII bearings to be 6805 in size but when i fitted some this morning the central hole is much to large, what is the correct size please?
thank you kindly
ht2 use that plastic top hat thing to reduce the size of the central hole. hope dont, and hence the central hole is a little smaller.
You can get replacements from [url= http://www.ukbikestore.co.uk/product/231/bbsp108/hope-bottom-bracket-spare-bearing.html ]here[/url]. But i think it would be a lot cheaper to go to a local bearing supplier and get them to order some in.
Not sure if they're available from ordinary bearing suppliers, I think they're "licensed" bearings.
Do they not have a number stamped or printed on, or on the seals? Alternatively try simplybearings or similiar with the ID OD and thickness and see what you find.
Hope have their bearing contract with FAG/INA. Try Brammer for supply. Bearing numbers are on the outer race.
Or just measure the inside and outside diameter and the width or try http://www.mountainbikecomponents.co.uk/for all your bearing needs.
enduro bearings fit but arn't stainless I couldn't source any cheaper
than crc at £16 each
http://www.bearingboys.co.uk/G_Flange_Bearings_-_Metric-2219-c
Top hat replacements here I think ,just need to work out the right size
sorry have stupidly binned them already is anyone able to confirm measurements/bearing numbers please and thank you
They should be 24mm ID with the same OD as 6805.
yup 37mm x 24mm x 7mm.
fitters i spoke to said they were "manufacturor only" and couldnt order them 🙁
These bearings should do it then!!
