Age-old 2x10 Medium...
[Closed] Age-old 2x10 Medium vs long cage question
[#8063012]
XT medium cage shadow+ rear mech is rated to 35t. Will I get away with this with a 11-36 / 26-38t setup? Or die horribly in flames if I try to shift into big/big?
I'm not in the habit of doing this - my 3x9 probably needs a longer chain to even make it onto 34x42, but there's a bigger risk of carelessness in 2x10.
Does the 'medium for 2x10' maxim still apply even with bigger cassettes for weaklings?
Posted : 19/09/2016 10:05 am
That probably wouldn't work as the range is 37, and I'd not risk it as riding a double does encourage you to ride big-big more often as it has a better chain line than a triple.
I'd swap the front with either a 28t or 36t, or go to a 11-34 cassette which should be more than enough on a double.
Posted : 19/09/2016 10:48 am
Might just make it - currently my lowest gear is 24-34. Still use it very occasionally as I prefer to sit and spin if possible.
Could just go long cage and make sure.
Posted : 19/09/2016 10:52 am
It's all well and good checking the numbers but, don't forget chain growth due to suspension action. Also, if you're using a clutch mech, a long cage might just make enough difference to chain tension to stop things flapping around in the smallest sprocket.
