Afine on a on-one s...
[Closed] Afine on a on-one singlespeed frame
[#2046920]
Brought a 2nd hand wheel and trying to work out how to route the cable, the alfine cassette joint pulley is positioned just below the chainstay, can this be re-positioned?
Any photos and tips would be greatly appreciated.
Thanks
Posted : 01/10/2010 8:00 pm
Hi
http://www.muddymoles.org.uk/2008/12/alfine_review.html
Here's mine. I ran the cable along the TT and down the chainstay (no Much gets in that way) using a grey non drive spacer.
Posted : 01/10/2010 8:13 pm
Thanks any close up photos, your flickr page is set to private?
Posted : 01/10/2010 8:26 pm
What specifics do you want to know?
I'll see if I have some more picts around or I'll take some more. I'm just off to the man cave (garage) to prepare the bike for D2D.
Posted : 01/10/2010 8:28 pm
Just cut the cable and run it SS
Posted : 01/10/2010 8:42 pm
You get different washers for the axle that hold the wheel at different angles depending where you want to run the cable
Posted : 01/10/2010 8:59 pm
For horizontal dropouts you need a yellow washer on the drive side and a white washer on the NDS.
Or is it the other way round...
I'll have a look on the alfine monkey in the mornin when i'm less pished. 😆
Posted : 01/10/2010 9:07 pm
Lol used to be singlespeed but was made redundant after getting the IF 😉 now playing around with all the spare parts I have collected over time,
Have silver, white, green and yellow spacers do I need different ones?
tonyg2003 what colour spacers do you use?
Posted : 01/10/2010 9:11 pm
Thanks Stu 🙂
Posted : 01/10/2010 9:13 pm
Just back from the man cave. Grey washer on the non drive side to run the cable up the seatstay. Points the arm nicely from the hub up to a gentle run along the seat stay. I only use one washer - never been a problem
Posted : 01/10/2010 9:15 pm
Only one washer, ok will have an experiment.
Thanks
Posted : 01/10/2010 9:25 pm
not an On One but a Surly frame,
with a tug nut to tension im using a silver serrated spacer just to stop the acorn lock nut running out of thread,
non driveside is a green serrated spacer,which stops axle rotating.
dont run Tug nuts each side as you could end up with your axle turning whilst cycling and a whole heap of s*** resulting from loosening bearings!
Posted : 01/10/2010 10:24 pm
