A2z disc mount
[Closed] A2z disc mount
[#6242231]
As per title does anyone have one ?, I bought a titanium Gary Fisher Prometheus with V/canti mounts but would like to put a disc on the frame (do not want to weld as frame is quite rare). Has anyone used these mounts and are they any good ?
Thanks Mark
Posted : 03/06/2014 10:40 am
I had one on an old Santa Cruz heckler and it worked perfectly.
Posted : 03/06/2014 10:46 am
Wiggle have them.
Posted : 03/06/2014 11:27 am
Yep - they work well on most frames, I had to dremel mine slightly to get it to sit straight (1994 m-trax Ti)
Posted : 03/06/2014 11:34 am
Had one on my old Marin Quake FRS. Worked fine.
Posted : 03/06/2014 11:35 am
Cheers guys I will need to purchase one (I think this cheap frame could cost me a few quid).
Posted : 03/06/2014 11:36 am
Works perfectly on my 97 Zaskar. You do need a relatively flat section of drop out for it to fit snugly.
Minimum disc size is 180 and I had to fiddle it a bit with files and washers to get my brake position spot on but it's been perfect for years now. A great product.
Heavy though.
Posted : 03/06/2014 11:46 am
 mj27
Got one in the spares box,used, but you can have it for £14 posted
Posted : 03/06/2014 11:58 am
mj27 drop me an email please.
Posted : 03/06/2014 12:22 pm
Mine worked perfectly too.
Not sure on the minimum size rotor though as I ran mine with a 140mm rotor.
Posted : 03/06/2014 1:18 pm
Worked well on my CX too. With a 140mm rotor.
Posted : 03/06/2014 1:24 pm
sorry, minimum disc size on a Zaskar is 180mm, it depends on the frame and where the adaptor 'sits' in relation to the drop out.
Posted : 03/06/2014 1:57 pm
 D0NK
So has no-one managed to rip the dropout off their [i]not disc compatible[/i] frame with one of these then?
Posted : 03/06/2014 2:08 pm
I have one of the arm type that connects to the V boss and bolts to the dropout, but you have to sort out something to shorten the hub.
Posted : 03/06/2014 2:31 pm
I also have one on my 96 Zaskar - went straight on without any fiddling, 160mm disc, SLX brakes. As above, been solid for a few years now.
There's a fair bit of meat on a Zaskar dropout - almost looks as though it was designed to fit it.
Posted : 03/06/2014 3:13 pm
