A quick favour?
[Closed] A quick favour?
[#989714]
Has anybody got a headset cup remover and / or a press that i can use for 10 mins in the Chester / North Wales area any time this week. Can drop you a few quid / beer / karma etc in return.
Phil
Posted : 27/10/2009 2:20 pm
 jfeb
Cup remover = large screwdriver and hammer (I use an old seatpost as it doesn't have the sharp edges of a screwdriver)
Headset press = mallet and block of wood.
I've done ti, alu and carbon frames with the above method. All worked fine.
(I took my time and was careful!)
Posted : 27/10/2009 3:50 pm
that method is not ideal if you have a decent headset 🙄
Posted : 27/10/2009 3:52 pm
bike shop will do it for about £10 surely??
if not thats day light robbery.
i was thinking about making some head set removers and selling them on for £20....
Posted : 27/10/2009 3:57 pm
Cheers Jfeb - would rather not risk using the hammer and block of wood method in case i **** it up.
Posted : 27/10/2009 3:58 pm
 jfeb
"that method is not ideal if you have a decent headset"
Not sure why not. I can imagine knocking out a fancy-pants headset cup might mark the cups slightly. Knocking them back in again with a mallet+wood should be fine. I can't believe a CK / Hope etc is softer or more delicate than the common or garden FSA etc headsets I have fitted.
But as an alternative, your LBS should be able to remove and refit for a nominal sum (free up to a tenner).
£23.50 😯
Posted : 27/10/2009 4:06 pm
 jfeb
£23.50 for an LBS to do it?
You need to change LBS!
Posted : 27/10/2009 4:20 pm
yep deffo a new LBS!!
head to b&q and build your own press for about £7
threaded bar (Also know as stud bar)
2 massive washers to fit over the cups
2 nuts to go on the threaded bar
shaun
also the seat post idea is very good!!
Posted : 27/10/2009 4:28 pm
Headset remover = cut and flared piece of copper pipe
Headset press = large vice = hammer + wood = piece of threaded bar with big washers and nuts on
Posted : 27/10/2009 4:37 pm
Yay - managed to persuade the other LBS to do it for a tenner.
Thought £23.50 was taking the piss, the cheeky barstewards
Posted : 27/10/2009 4:43 pm
