A .gpx file editing...
[Closed] A .gpx file editing question
[#7819008]
If I have a .gpx file for a circular route, and I want to change where the start point is, can I just change the order of the waypoints in the file?
And would anyone care to recommend a .gpx editor (although they're not exactly tricky, I could do it in Notepad/Excel I suppose)
Posted : 10/05/2016 12:14 pm
I used bikehike a lot for this. You can reverse, cut and merge files (using the options submenu for some of those)
Posted : 10/05/2016 12:25 pm
You can open the file in a text editor (Notepad++ is quite nice) and move points around. It'll mess the time stamps up but I don't know if that'll impact on anything. Only hard bit doing it this way is finding the new start point from the list on waypoints.
Posted : 10/05/2016 12:53 pm
Yep done this, worked fine as a track/route to follow on my Garmin 510.
Posted : 10/05/2016 1:13 pm
Does it matter where the start point is? Jump on your bike and follow the line.
The GPS won't care where the start point is, and you can always add an extra waypoint manually for real start to get you directly back if needs be.
Posted : 10/05/2016 1:15 pm
Garmins also have the option of reversing the course when you start (at least 1000 does).
Posted : 10/05/2016 1:17 pm
cheers all, I'll download Notepad++ (I'd forgotten about that, great little text editor)
Posted : 10/05/2016 1:37 pm
