1) Stop calling it darkside.
2) Reach is much more inportant than inside leg length. About the only way to find out is to go and try a few out, different manufacturers have different ideas about sizing especially when you throw the slight variances of compact, semi compact and 'traditional' (ie horizontal top tube) design into the mix. Those bull-horn bars may alter things a bit too, they're usually slightly longer than normal drop bars.
Go to your lbs and ask their advice.
1) sorry about the Darkside comment, just seems to be the done thing on here
2) I may give this one a miss, online reviews aren't too favourable and i'm just getting excited because it loks a bit like the Charge Plug which i can't afford at the moment
3) I might just go with the Carrera which i know fits and i'm not going to be too stretched out on the risers bars as I would be on the bullhorn/road bike frame
Cheers anyway
56cm at a guess..
But try before you buy is never a bad idea..
I found this useful
[url= http://www.ribblecycles.co.uk/FrameSizeHelp.asp ]frame sizing[/url]
I'm 6'1" and ride a 56cm. My friend is 6" and rides a 58cm. I think I have a slightly shorter upper body. You'll be one of those two but you need to sit on both and see how you feel.
6' and ride a 57cm
