5800 shifter with 5...
[Closed] 5800 shifter with 5700 front mech - compatible?
[#8115749]
I bought a replacement 105 shifter after a crash a while ago and just getting round to fitting it when i realised it's a 5800 rather than 5700.
Its left hand/front and they are both double, but is the cable pull the same for the 10 and 11 speed versions? If necessary I could get a new front mech, but would like to avoid spending any more on the commuter at the moment.
Posted : 19/10/2016 11:18 am
Think 11 speed/x800 series front mechs are all using the long lever front mech. You might need a new one.
Have you checked the shimano compatibility chart?
Posted : 19/10/2016 11:35 am
the chart doesn't seem to have an opinion on it - doesn't show mixes of 10/11 speed. maybe because it doesn't work, but it doesn't explicitly say so
Posted : 19/10/2016 11:51 am
I was in the same position shifter/mech wise and ended up buying a new mech as I couldn't get the shifting quite right. The new mech sorted it straight away.
it's not compatible
Posted : 19/10/2016 12:25 pm
thanks for the advice everyone.
Posted : 19/10/2016 12:37 pm
