44mm Headtube &...
[Closed] 44mm Headtube & 1.5in internal headset
[#6015221]
Looking at a frame with a 44mm headtube. It says that to run a 130mm or longer fork use an internal cup headset. Do you get a 1.5 inch internal bottom cup for a tapered steerer into a 44mm headtube? Or to use a longer travel fork am I stuck with using a 1-1/8in fork?
Posted : 06/03/2014 2:19 pm
For a tapered steerer you will need to use an external headset, and for a modern longer fork chances are it will be tapered, bit catch-22 daft really.
For the sake of 10mm run whatever headset fits the forks you want to the frame you want.
Posted : 06/03/2014 2:23 pm
Cheers, thats what I though the case was.
Headset sizes are a pain in the arse!
Posted : 06/03/2014 2:26 pm
Here is my Ragley Bigwig.
Ragley say that to run a 140mm fork I should use an internal bottom cup in the 44mm headtube; but since the Fox 34 is only available tapered steerer I had to use an external cup. Rides fine btw.
Posted : 06/03/2014 2:43 pm
Cheers again, it was the Bigwig I was looking at.
Posted : 06/03/2014 2:50 pm
