2x10 medium cage?
[Closed] 2x10 medium cage?
[#4073433]
I'm about to go fully 2x10 on my mojo, running SLX double up front (24 36) with a 36-11 rear cassette, 37t config.. I know that shimano say 35t I think for the new saint etc medium cage but bearing in mind I'll probably only use granny with the top 3 at the rear will it be an issue? Was previously running 11-34 9sp with medium saint and that was fine...
Cheers!
Posted : 16/06/2012 1:32 am
 kevj
I'm running 2x10 on my mojo with 28/38 up front and 11/36 on the rear and an XT med cage mech with no issues at all. And I can get every ratio including both big rings smoothly.
HTH.
Posted : 16/06/2012 7:58 am
Cut chain for large+large + 2 rivets as normal.
Just possible you will run out of cage for small+small, but it will still work...any slack will be OK until you start bouncing down a rock garden.
PaulD
Posted : 16/06/2012 10:23 am
I'm running 38/28 and 11-36 and went with the long cage just to be on the safe side.
With you running slightly smaller front rings I'd have thought it would be fine.
Posted : 16/06/2012 10:37 am
Will be no problem at all.
New shadow+ (with clutch system) mechs worth a consideration as reduce chain slap greatly, so in event of using granny and lower section of rear cassette, controls chain to much greater effect even when mech is at extremes of operation angles.
Posted : 16/06/2012 10:44 am
Sorry to slightly hijack thread but related question:
Will a medium cage be okay for 1 x 10 with 11-36 cassette and something between 30 and 36 chainring? Just one ring to consider so hoping it'll be fine but quite new to MTBing so unsure.
Ta
Posted : 16/06/2012 11:26 am
Yes. Your situation requires less chain capacity than the same cassette with double chainrings as detailed above.
Posted : 16/06/2012 12:06 pm
Cheers fella
Posted : 16/06/2012 12:10 pm
You realise the new Saint is small cage only? 2013 saint is 1x10 exclusively 🙁
Posted : 16/06/2012 1:03 pm
Off topic mate but I've sent you an email ref your mates 456
Steve
Posted : 16/06/2012 1:09 pm
Yeah - I do now 🙁
Might try running 1x10 instead then - just would've been nice to have granny as an option for when i'm feeling really lazy!
Posted : 16/06/2012 6:48 pm
Just thinking though, what would be the effects of running it on a 2x10 though, whats the worst that could happen - just a slack chain if I dropped onto granny gear? (which if I did I'd be running 26 front 36 rear anyway...
Posted : 16/06/2012 10:26 pm
