2bliss Advice Neede...
[Closed] 2bliss Advice Needed.
[#2712813]
Buying a bike with 2bliss tyres, a spesh pitch pro.
a) what sealent, I've a bottle of JRA wheel milk, but its years old so must be off by now.
b) presumably ghetto'ing the rims with electrical tape will work?
Posted : 03/05/2011 3:17 pm
No one?
Posted : 03/05/2011 4:28 pm
Any sealant you want and yes electrical tape will prove to be a suitable rim strip.
Posted : 03/05/2011 4:32 pm
Has it dried out/separated/gone lumpy? If not then it's fine.
Possibly, but such solutions are just a recipe for hassle in my experience. Use a UST rim and your 2-bliss tyres will go on and off very easily and go up using any old pump.
Posted : 03/05/2011 4:41 pm
Brother in law runs a kwikfit so air supply not a problem 🙂
It was a yellowy pink last time I saw it, but not lumpy 🙂
Posted : 03/05/2011 4:49 pm
2BLISS!!! HA HA I GEDDIT!!
TOOBLISS !!
BRILLIANT!
Posted : 03/05/2011 4:53 pm
I 'tubelessed' the 2Bliss tyres on my Stumpy FSR - Purgatory on the front & Captain on the back. It was dead easy.
Only problem I had was trying Spesh Airlock sealant, which was rubbish.
I used electrical tape - a loop over to one edge, a loop over to the other edge and a final loop in the middle. I used Wickes electrical tape in red, as everyone knows red is the fastest.
The valve lockring needed a bit of tightening with pliers to get them to seal properly.
Once that was done, the tyres went up without sealant with just a track pump. When I was happy that they were actually going up, I stuck the sealant in (I ended up using Stans) and they were fine.
Recently the front refused to stay inflated, but it hadn't been used for a while and seemed a bit low on sealant. I stuck a squidge more sealant in & sloshed it round loads and 3 weeks later it's still fine.
The only problem I've had with them, is that the Purgatory on the front is quite a loose fit (easily on & off with no levers) & it's burped a couple of times when running fairly low pressure and I've come a cropper. I now keep them up at about 35psi. I only converted them to avoid thorn punctures in Spain, so am not bothered about using them at low pressures.
Posted : 03/05/2011 4:55 pm
backhander - Member
TOOBLISS !!
BRILLIANT!
Glad someone does....
Your post was possibly lacking a 'BOOM BOOM'??
You are aware that "2Bliss" is the name Specialized use for their tubeless compatible range of tyres, aren't you??
Posted : 03/05/2011 4:58 pm
BOOM BOOM
Posted : 03/05/2011 5:19 pm
I've been using the Specialized Airlock sealant. It seems to do the job although I am getting a small amount bleeding through the sidewalls, though I think this is down to the 2bliss tyres rather than the sealant.
Posted : 03/05/2011 8:03 pm
I use 2bliss tyres on ghettoed on 717's and stan stripped 719's all inflated realy easy with a track pump
Posted : 03/05/2011 8:27 pm
backhander -
Member
BOOM BOOM
Ha ha!
:o)
Posted : 03/05/2011 10:03 pm
