26.8mm post in a 27...
[Closed] 26.8mm post in a 27.2mm frame - bad idea?
[#2059510]
Well after a LOT of deliberation I just went and ordered myself a 456SS in that nice bright orange to try out the whole slack hardtail thing 😀
Anyway it has a 27.2mm seat post size. Can I safely use a 26.8mm post in it or will the .4mm make enough of a difference to cause slippage or damage to the frame?
Similarly will it be ok with a 30mm seat clamp where it should be using a 29.8mm?
Posted : 05/10/2010 9:27 pm
Snappity-snap-snap
Posted : 05/10/2010 9:28 pm
It'll be fine. It's all a con those different sizes.
Posted : 05/10/2010 9:29 pm
I glued a piece of beer can on to my 26.8 post with araldite and it's a very good fit. If you wanna raise and lower the post a lot it might be a bad idea though.I cut 3 sections of can to make it a bit more manageable and zip tied them down.
Posted : 05/10/2010 9:49 pm
27.2mm posts are pretty common and easy to get. Not worth bodging IMHO.
Posted : 05/10/2010 9:51 pm
hmm might be able to get away with 26.8 in 27.0 especially if you used a coke can. Not sure about 26.8 in 27.2 would be slipping alot
Posted : 05/10/2010 9:53 pm
Not a cat in hells chance. Dont do it.
27.2 has got to be the most common size out there.
Spend another £30-£40 on a s/h Thomson.
30.0 clamp will be fine though.
Posted : 05/10/2010 9:59 pm
Will give it a miss then. Anyone got a 27.2 thomson they want to sell? 🙂
No, but looking for 26.8!
Posted : 05/10/2010 10:06 pm
Going to keep mine for a while til I've decided whether the 456SS is going to stay (hopefully will!), but will give you a message then to see if you still want it.
Posted : 05/10/2010 10:11 pm
just get a bit of 0.2 mm shim steel shim steel that's what I did with a use post I had and it worked fine.
Posted : 05/10/2010 10:45 pm
I have a genesis 27.2 seat post and I've got the seat clamp to match if you're interested. I've also got a 26.8 use suspension post both are practically brand new.
Posted : 05/10/2010 10:48 pm
Dasha - I am if Tom's not. Any details?
Posted : 05/10/2010 11:03 pm
Hi theotherjonv, I've emailed you on your profile E mail
Posted : 06/10/2010 12:33 am
My bodge hasn't slipped, in fact it's quite a tight fit.
Posted : 06/10/2010 12:45 am
why bodge something you can buy for chips? You canpick a decent 27.2 post for a tenner SH on ebay. I once fitted a27mm in a 27.2mm and it was fine. 26.8mm will not do the job though. The 30mm seat clamp is fine though
Posted : 06/10/2010 2:31 am
I used a 27 in a 27.2 and it was blooming annoying as it kept slipping when I adjusting the height and also it has sl. deformed the tube as now its sl. too tight with a 27.2 so a 26.8 will not tighten up enough to be sweet! Try a DIY shim - that would prob work.
Posted : 06/10/2010 7:50 am
Tom, check your WTD add
Posted : 06/10/2010 10:03 am
