2013 Reba RL Solo A...
[Closed] 2013 Reba RL Solo Air Compression questions
[#6246512]
I bought the above fork in a 120mm 26" variety a few months ago and due to work commitments have only managed to ride it for about 100 miles. I bought it to upgrade the Recon Gold TK fork that came with my bike as I was looking to shed some weight and take advantage of a 15mm thru axle wheelset that I purchased.
The fork has worked ok but I can't say that the performance is ultimately that much different to the Recon, in fact it feels a lot stiffer / less plush, although this could be because the fork needs more time to bed in.
I can get the rebound dialled in nicely but I'm not sure how the compression damping knob works, or if it works at all. There is about 5 clicks from the 'open' position on the blue compression knob to the lockout mode. Open is just that; fully open, but the fork feels quite stiff over small bumps and I find it nearly impossible to get more than 70/80% travel on drops / jumps / bigger hits, even though these feel a lot plusher.
When set to lockout the fork nicely locks out yet retains a tiny bit of travel like the lockout on my Recon so no problems here.
The fork is the same one as in this video (not my video) [url=
Should the regular, non-PopLoc Motion Control damper from the 2013 / 2014 models only have 5 clicks of compression, and should I feel more of an effect with each click? At present fully open - clicks 2 and 3 feel the same, with 4 and 5 people a complete lockout.
Posted : 04/06/2014 7:30 pm
Run the forks a bit softer?
Posted : 04/06/2014 8:55 pm
