[Closed] 2 x 10
[#4727843]
I am currently riding a scale 29er with an XT triple which is wearing out and would like to change for a double. My current set up is front d = slx fc m660 ( 34.9 ) 10 speed, rear XT RD 780 SGS 30 speed, shifters sox sl m660 - 10 rapid fire +. What do I need to purchase to make the change ?
Thanks
Posted : 08/01/2013 3:59 pm
Just your chainset by the looks of it and flick the switch on the bottom of your shifter from 3x to 2x
Posted : 08/01/2013 4:01 pm
What chainring size are you going for?
Doing the same on a light XC-ish bike myself and considering 26/38.
(with 11-36 cassette)
Posted : 08/01/2013 4:09 pm
M660 shifters don't have the mode convertor switch on them, that is only on the newer M670 model.
You could just swap the chainset to a double and use the limit screws on the front mech. I would be tempted to buy a specific double front mech though. I would also consider swapping the rear mech to a medium cage but it is by no means neccessary.
Posted : 08/01/2013 4:42 pm
Thanks thered, not seen the switch on bottom of shifter, so that will sort out front derailleur and shifter ?
chakaping, i am thinking double xt 26/38 which i think will be fine for xc racing ?
Posted : 08/01/2013 4:44 pm
Mister P, so you reckon new chain set, Shimano XT M786 10 Speed Double Front Mech - Conventional and use my M660 or do i need to change it ?
Posted : 08/01/2013 4:52 pm
Recommend going 24/38 on your Scale 29er, dependent of course on how hilly it is were you are, and your rear cassette? 11/36? Best to have the correct front mech too.. I have 26/38 on my Scale and it’s great but I would like slightly lower gearing on the long uphill sections hence recommending 24
Posted : 08/01/2013 5:23 pm
11/36 rear and 26/38 front on my Remedy, fine for everything!
Posted : 08/01/2013 5:49 pm
