135x10mm rear axle ...
[Closed] 135x10mm rear axle questions
 dobo
[#6731471]
My switch hubs appear to be capable of using a 10mm rear axle, my 29er frame is an ordinary open drop out currently using standard qr.
If i get the superstar 135x10mm adapters can i then use something like the DT RWS thru bolt?
http://www.superstarcomponents.com/en/switch-rear-adaptor.htm
http://www.dtswiss.com/Components/RWS/RWS-Thru-bolt-en
Are the RWS any good, worth it on the rear? any other options to consider?
I've never really been interested in thru axles until i got a 15mm axle on the fork, which defiantly noticeable improvement.
Posted : 27/12/2014 7:59 pm
You'll be fine to use the DT skewer. I've got switich hubs and have the [url= http://www.superstarcomponents.com/en/ultralight-alloy-10mm-rear-qr-through-axle.htm ]Superstar Ultralight axle[/url] which works great.
Posted : 27/12/2014 8:05 pm
 dobo
woodster thanks for that i didnt even see the ultralight on their website!! at that price its worth a shot i guess.
fingers crossed nobody comes along to say their ultralight axle exploded.
Posted : 27/12/2014 8:14 pm
Got the standard superstar one and it's been faultless. It's red.
Posted : 27/12/2014 9:09 pm
Would this replace a bolt through 10mm,My Kona Entourage uses 10mm bolt through,which i need to use 2 different size allen keys to remove,
Posted : 27/12/2014 10:39 pm
