102 and 104mm BCD C...
[Closed] 102 and 104mm BCD Chainrings
[#2326326]
Why do both sizes exist?
There's no way a 102mm chainring would fit a 104mm spider is there?
I know I should have checked, I remembered it was just over 100mm I wanted, and assumed there would only be one standard close to 100mm.
Posted : 31/12/2010 12:01 pm
 jonb
Never heard of 102mm bcd.
Are you using a shimano crank with a non shimano ring. I singlespeeded a deore crank and had to do a little bit of filing to get a standard 104bcd ring to fit. Shimano make their cranks in a way that many non shimano rings do not fit without modification.
Posted : 31/12/2010 12:20 pm
104mm is the standard BCD of most 4 arm cranks.
102mm is XTR M960 inner as far as I can remember, the middle and outer were 146mm.
You cannot fit a 102mm on a 104mm or vice versa. Some rings will need the tabs filed slightly to fit on certain crank arms but generally they will fit.
Posted : 31/12/2010 12:26 pm
the only 102mm were M960 XTR I think.
http://www.wiggle.co.uk/shimano-102-bcd-xtr-m960-middle-chainring/
Posted : 31/12/2010 12:28 pm
This is the ring I bought:
http://www.chainreactioncycles.com/Models.aspx?ModelID=17275
Looks perfect for what I want it for, though I should have checked the size of it. So this would only work on XTR cranks then. Great. Why would $himano do this?
Posted : 31/12/2010 12:40 pm
Yes, that ring is 102mm for XTR M960 only.
You need one that says 104mm in the blue text where the buy button is.
Posted : 31/12/2010 12:51 pm
Yep, annoying, will get onto it....
Posted : 31/12/2010 1:04 pm
thread resurrected through the wonders of serach.
I've got a 1999 vintage LX chainset with a wierdo spider thing. i'm absolutely certain it's a 102 bcd for the middle chainring.
I'd planned to take a hacksaw to it, take off the outer, clean up the inner and use it with UN72 I've got hanging round on a singlespeed.
What are the chances of finding a 4 arm 102bcd, 46-48T, 1/8" chainring?
No joy after a while googling. Any ideas?
Am I in moon/stick territory again?
Posted : 03/03/2011 8:23 pm
Ha. Erm.
Just measured it again and it's very definitely 104mm. Must have used one of those shonky foreign rulers last time.
Posted : 04/03/2011 9:07 am
