100mm adjusted 20mm...
[Closed] 100mm adjusted 20mm bolt through rigid forks...?
[#5745310]
Is there anything else in existence apart from the dmr trailblade?
Posted : 04/12/2013 8:33 am
 P20
I think salsa do some
Posted : 04/12/2013 10:15 am
just looked o their website and found nothing
Posted : 04/12/2013 10:59 am
 nbt
Salsa do bolt through forks but they're 15mm now, and I think they're 29er sized
Posted : 04/12/2013 11:04 am
[url= http://www.identitibikes.com/products-details.php?id=FKITRJ2K ]Identiti Rebate 1420[/url]
Posted : 04/12/2013 11:10 am
trailblades look like the best option then at £80ish
Posted : 04/12/2013 11:31 am
Yep, if you can find a pair some of last year's Salsa CroMoto 29er Grande Maxle forks should be perfect. They're 29er but 80mm adjusted (467mm a-c) so should be (roughly!) similar to what you want.
Posted : 04/12/2013 11:56 am
Oooh I'll look into that thanks.
Posted : 04/12/2013 11:57 am
I would give Triton cycles a call, 0208 508 0682, there's none showing on the website but you never know. Also, they are around £190- a bit pricey for some!
Posted : 04/12/2013 12:01 pm
£190... I'm out.
Posted : 04/12/2013 12:07 pm
