£100* to spend .......
[Closed] £100* to spend .... New flat bar needed .... Carbon or Ti
[#6210204]
So looking for a new flat bar .
I've not used Ti or Carbon for a bar before so new territory for me.
Thinking Thomson carbon or Kingdom bikes Ti.
Looking for flat but a reasonable amount of sweep.
Thoughts?
*ish ..... certainly not a lot more .....
Posted : 22/05/2014 2:10 pm
Only ones I've found (at 740mm) with more than 8 or 9 degree of sweep are Syntace Vector Carbons (740mm 12degree).And they are £150ish.My Enve sweeps are ok but I don't see why the can't make them so they feel the same as the risers.
Posted : 22/05/2014 2:15 pm
 bol
I've got some 3T Extendo bars, which are 740 wide with 12 degrees of back sweep. They're supposedly flat, but they're eccentric. I have found they've got too much sweep for me, so have effectively been using them as risers. Might be worth a look though if sweep is what you're after. Currently £70 at Wiggle I think.
Posted : 22/05/2014 2:31 pm
I'm running exotic carbon bars 750mm and very light ... £65ish I think on the bay(bike fridge) ragged them a while no issue 8)
Posted : 22/05/2014 2:33 pm
Possibly Kinesis Strut? IIRC the flat one has quite a lot of backsweep, and they're £80 at Winstanleys.
Crank Bros might do one as well, I didn't pay much attention to the flats
Posted : 22/05/2014 3:16 pm
I've got a set of exotic 750mm on a bike I just bought - look mint but I'll be strapping things to the bar on this bike so will go standard aluminium. £37.50 posted?
Cheers,
Ian
Posted : 22/05/2014 3:26 pm
kingdom ti flat bars here mate brilliant!
Posted : 22/05/2014 4:20 pm
jonny rocky mountain - Member
Were they okay to deal with?
What sweep did you o for?
Posted : 22/05/2014 4:24 pm
Just get Aluminium - plenty light enough - compliance/ dampening not needed for handlebars... Forks and tyres will sort that ...
Posted : 22/05/2014 8:57 pm
