Zero stack top 1 1/8 to 1.5 bottom - recommendations and (you never know!) anyone got a King one for sale? 🙂
Hope Pick N Mix
+1 Nuke 🙂
How do you 'buy' the Hope pick n mix though?
I think I need a zero stack 44mm diameter top headset and a 1.5 to 1 1/8 reducer bottom cup (ideally as low stack as possible).
Fill ya boots 🙂
http://www.ukbikestore.co.uk/product/24/hsc_lower/hope-pick-n-mix-lower-headset-cups.html
http://www.ukbikestore.co.uk/product/24/hsc_upper/hope-pick-n-mix-upper-headset-cups.html
I think the HS136 just reduces the diameter of the headtube (though not entirely sure to what) and you still need another lower headset to pop in there.
Edit: sorry, that should be the other way around, that the HS136 pops into the headset and reduces the diameter from 1 1/2 to 1 1/8 so you'd need E and HS136 at the bottom... probably.
Hora, you walk into Northwest MTB and say I need a headset for this... and then you walk out with all the bits you need.
HS136 is an £8.99 aluminium spacer that replaces the crown race. It's got an external diameter of 1.5" and an internal of 1" 1/8th. slides on and has a lip to keep the crap out.
2 + D
Will do. Ta 😀
+1 what wozza said.
2+D is fine unless you want a lower stack hight.
BTW King don't do integrated.
This isn't for a Spesh Enduro 2010/11 is it Hora? I'm having difficulty figuring out what I need too...
2011 Turner 5spot.
I've given up on UKbikestore- been trying to order them for almost 20mins.
Just be patient - they are normally very good?
Edit: all seems working fine here now?
Go to basket- then prompts me to login again. Login (basket empty). So go back and re enter items (whilst logged in) - same again. 😐
hmm- sounds like a cookie problem 🙁
Mine seemed OK - did a dummy order and all went through OK?
Why not give them a ring - they are very helpful?
02392 528 932 🙂
Or if you can't phone try CRC?
http://www.chainreactioncycles.com/Models.aspx?ModelID=70725
http://www.chainreactioncycles.com/Models.aspx?ModelID=70727
Did you get them Hora?
18bikes do them.
I'm thoroughly confused.
Hope tech say its should be 2 B but from my thinking the 2011 5spot headtube is 1.5 throughout giving a 44 internal measurement throughout??
Ah it is 2 B.
44 internal straight headtube so bottom cup is 44/30
foxyrider I called ukbikestore and was lucky in that a knowledgeable chap answered. Its actually a straight forward 44mm integrated hope headset which luckily is the same as 2 B.
Thank you
hora ukbikestore are great for that, every time i have called to ask about a part the person on the other end of the phone has ben really knowlegable.
You sir a a jammy git for getting a 2011 5 spot frame, even more envious now. With the new 44mm inigrated headset size at the front you will be able to run tapered steerer forks with a new lower cup and race if you so decide later down the line.
Full marks to SilverFish UK and Merlin for a quick turn around and customer service.
I've never had a warranty issue before on a frame so I was abit 'worried' how long it'd take etc. It took 1 hour.
