What I learned abou...
[Closed] What I learned about chain length on a full suss (costly idiot content)
[#3446699]
right, 2 night rides, within 1 week, on same bike, same outcome, finally learned lesson.
= on a full suss, with a chain device, with a 36tooth big ring double, simple big-big and 2 link overlap chain length is not enough. esp when hit a dip and need to crank out the hole.
Grraaaaaaccckkkkk 2 x rear mechs totally eaten and 1x mech hanger. Idiot. Figured it out last night and feel like an idiot. 😳
feel my pain, and shame, but rather glad I have figured it out!
Kev
Posted : 10/12/2011 1:46 pm
 br
Yep, take the air out of the shock when working out chain length - just to make sure.
What FS is it that seems to move the axle backwards so far, or is it the chain device - you did take the chain device into account when working out the length, didn't you?
Posted : 10/12/2011 1:49 pm
I'm assuming you also removed the shock or the air from the shock and fully compressed the rear suspension when sizing the chain?
Br and bob = no and no. Well, now, yes, but both of those points are exactly why I am a mong.
In my defence, I have only ever been working it out previously on triple ring front, and I would never actually ride big-big on the triple, on any bike, so it has never been an issue. Also, on the mega, I have only been using it for bike parks tis year so these trail rides are the first time I have really ridden it like a trail bike. Poo!
Posted : 10/12/2011 2:03 pm
dont worry, same thing happened to me, ok, well it only happened once to me 🙂 . Annoyingly it was when I lent my bike to a mate and he did a drop in big \ big rings whiich I probably wouldn't have done .
when I finally put enough links in to allow the full movement on big \ big the chain was slack in the top three gears at the back when using the granny ring. anyone else found this ? I'm thinking that the solution would either be a chain device or a longer cage mech
Posted : 10/12/2011 3:04 pm
Solution is don't use those gears. You could run a longer cage mech, but they're not good gears to be in anyway, and it's not catastrophic if you select them by accident. A chain device would surely just mean you needed an even longer chain to avoid problems in big/big, which would nullify any benefit when in small/small?
Posted : 10/12/2011 9:53 pm
