What flats for a ro...
[Closed] What flats for a road bike?
[#2530692]
I've just got my first non-MTB. SPDs scare me, so they came off straight away. I'm using some spare Shimano DX flats for now.
I'm assuming there are lighter road flats out there, but I just don't know. What flat pedals should I be using?
Posted : 04/03/2011 10:03 pm
flats on road will be awful, try toe clips?
Posted : 04/03/2011 10:05 pm
Can't you just use some track type pedals with toe straps.
Have a look [url= http://www.sjscycles.co.uk/toe-clips-dept300/ ]Here[/url]
Posted : 04/03/2011 10:07 pm
 mrmo
flats on a road bike!! MTFU fit clipless pedals, toestraps are scarier than clipless, and flats, unless you have a medical excuse have no place on a road bike.
Posted : 04/03/2011 10:11 pm
[url= http://www.sjscycles.co.uk/pedals-flat-dept871_pg1/ ]And here for pedals[/url]
And ignore the mtfu nonsense, if you feel comfortable with flat pedals then that's fine. Power grips would be worth a look too.
Posted : 04/03/2011 10:18 pm
After some experimentation I finished up going for a pair of MKS GR9 and some strapless toeclips like the Zefal or Delta ones in the link above. The GR9's are also to be found amongst those listed on the SJS site via the link above. I agree with Gary M, go with what makes you feel comfortable. I found that this combination gave me some stability without feeling tied in.
Posted : 04/03/2011 10:47 pm
Can the mods delete this thread please?
Posted : 04/03/2011 10:49 pm
Why? Perhaps instead of flats the op should have said standard pedals in case anyone got offended. 🙄
Posted : 04/03/2011 10:53 pm
give the guy a break. he may be a pensioner or infirm and not be up to using a pedal system used by the able bodied.
Posted : 04/03/2011 11:00 pm
 mrmo
I will try and be a bit more constructive on this. Toe straps work best when tight, but by being tight can be a real liability when riding in town, or when you forget to slacken them off 😮
Yes there is a learning curve with clipless pedals, maybe a few hours to get the hang of flicking your heel to get out. The advantages are many not just the ability to put power down, but your feet aren't going to slip off at the wrong time, you can ride up hill far easier as you can actually pull up with out fear of you feet coming off the pedals. Then there are things like being able to use overshoes in the winter to keep feet warmer. No straps cutting blood off to your toes. Better lean angles when pedaling through corners.
disadvantages only really apply to pure road pedals when you want to walk, but spds solve that if your looking at touring rather than racing as a motive.
Power grips still restrict the foot more than clipless pedals.
Posted : 04/03/2011 11:05 pm
Cornering clearance with flats will be a problem! Get some SPDs, far more user friendly than clips.
Posted : 04/03/2011 11:20 pm
[i]Power grips still restrict the foot more than clipless pedals[/i]
No they won't. Having used power grips in my early days of mtbing I can confirm that's not the case at all.
Posted : 04/03/2011 11:22 pm
I'd say at least give some MTB SPDs a go before giving up on them.
I've recently got my first road bike and, having never used SPDs before, I don't find them a problem at all - admittedly I've got them set as slack as they'll go to start with.
Posted : 05/03/2011 12:16 am
 wors
Practise clipping in and out before you go out on a ride. You only need to unclip in traffic/lights anyway. Fwiw i use clipless on the road but prefer flats on the mtb.
Posted : 05/03/2011 12:23 am
have a few short bikepath/towpath rides on the spds. you'll have a few comedy sideways falls when stopping/starting (if like me), but you'll slowly get used to them. Then after a while you won't be without them.
Posted : 05/03/2011 12:25 am
If you're doing the toes straps up properly then clipless will be much easier to get out of.
And using clipless on the road is generally easier than off road. You tend to have more warning of when you need to stop and disengage.
Go for some SPDs or Crank Bros and MTB shoes and then you'll be able to walk as well.
I'd really say to try SPDs, it really is better. But, I use flats because my knee's foobar'd, and I'd say don't worry excessively. In fact my commuter's got the horrible wellgos that came on my cheapo Carrera mtb. You don't need much in the way of grip so spiky flats are excessive and just a recipe for catching yourself while pushing the bike around. If I had to buy a set I'd possibly just get some wellgo mg1s and take most of the pins out, there are nicer more road-oriented flats but they're expensive.
The trick will be to work on a really nice spin, which isn't exactly brain surgery but still not that easy to do.
Posted : 05/03/2011 12:34 am
This too.
Cheers for all your posts. Food for thought there.
Posted : 05/03/2011 8:30 am
