Tubeless and WHW- w...
[Closed] Tubeless and WHW- will I die?
[#4922157]
Running nobby nic 2.25 Evos non-tubeless with Stans fluid on Rovals fitted to my Yeti 575.
Attempting the WHW at the end of April- will be carrying a couple of tubes and patches in my bag, will also clean the tyres and put fresh fluid in..
I've heard there's some very large water bars for hopping/pushing over on the route and just wondering if there's any point sticking with the tubeless- had them set up like that almost a year with no problems at all..
So- pita or just stick with the current setup?
Ta.
Posted : 02/03/2013 7:03 pm
you'll prb die, so good luck and make sure you set up a STW trust fund
Posted : 02/03/2013 7:18 pm
If you do flat, you put a tube in - what's to worry about?
Hang on - I'd forgotten about the tyre shredding midge of Lochaber............
Posted : 02/03/2013 7:25 pm
Will put my affairs in order before I go then..
Edit- the whatnow??? 😀
Posted : 02/03/2013 7:27 pm
The fact there are water bars is reason enough for staying tubeless!
Posted : 02/03/2013 7:35 pm
Yeah, go tubeless and find a nice cushy pressure, the extra suspension and traction on the climbs is worth it! I actually managed to scrabble up a few of the switchbacks* on the Devil's staircase running tubeless rubber queens somewhere between 25 and 30 p.s.i.
*before common sense and lactic took over...
Posted : 02/03/2013 7:38 pm
 br
No, I ran T/L on a HT. View from the top of the Staircase in the summer.
Posted : 02/03/2013 7:53 pm
Tubeless it is then.
Posted : 02/03/2013 8:05 pm
Fairly shocked you haven't died already. Rovals on a Yeti just sounds wrong.
Posted : 02/03/2013 8:13 pm
They seem to be fine. Fairly light, reasonably wide and I got a bargain price when I bought them...
Not sure about the red alu nipples but hey ho.
Posted : 02/03/2013 8:21 pm
