Trolled alfine 11
[Closed] Trolled alfine 11
[#3569302]
Just broken my alfine 11 after 3 months. Just riding along off road in 1st, applied pressure to the pedals and it skipped a gear. Thought it was debris in the gear change mechanism, but it was all clear. Carried on riding as normal, then 5 minutes later it happens again, this tIme I've lost 1st 3rd 4th 8th and 9th.
Has anyone else experienced this?
Posted : 16/01/2012 10:56 am
Cable streched? can that have an effect?
Posted : 16/01/2012 11:01 am
Check the cable run is smooth and the yellow dots are lined up in 6th.
After that, it could need a trip back to Madison via your retailer. A search on here is your friend......
Posted : 16/01/2012 11:05 am
This could be through cable stretch, take it to a bike shop and get them to have a look and possibly set it up again. If that isn't the problem and it is broken it is a Madison product and their warranty is excellent.
Could it be the cold?
Posted : 16/01/2012 11:08 am
Cable all good and correctly aligned. Had to replace the whole cable asslby after a ride in the peaks.
Posted : 16/01/2012 11:09 am
[i]Had to replace the whole cable asslby after a ride in the peaks[/i]
and it's immediately not working or after a few miles? A new cable woudl stretch I'd imagine or (dare I say it) not quite fitted correctly if it's not workign from the off.
Posted : 16/01/2012 11:10 am
The cable was replaced before Christmas and has been fine ever since. It was below freezing on Saturday but it was an hour and a half into the ride
Posted : 16/01/2012 11:14 am
Roger at HFTH reckons you can't rely on the yellow dot - set it up so that it works (ie try it slightly off in either direction and see if it sorts it).
Katie's first Alfine had a skipping problem. The second seems to have lost all it's oil through the drive side.
#notarohloff
Posted : 16/01/2012 11:15 am
Did try aligning either side of the dots, but it made no difference.Do Itake it from that you've already broken two Alfine 11s?
Posted : 16/01/2012 11:18 am
It's not looking good for the second one. Wondering what to do with it - don't really want to spend full whack on an oil change kit only to have it all leak out.
Posted : 16/01/2012 3:40 pm
I'm on my second one, first one lost 2nd gear. Current one is much happier with the lines misaligned by ~1mm slacker to get both 2nd & 10th without slipping. Try pedalling gently around while twiddling the adjuster one click at a time & hopefully you'll find a position that works. You have to ask yourself whether you should be needing to do this on your expensive investment though? They are good when they work - just wish I had more faith that it will last...
Posted : 16/01/2012 4:36 pm
the 8 seems much better than the 11 for reliability
Posted : 16/01/2012 4:51 pm
Nice that Shimano are doing there r&d work in the field ( with us ) again, still they must have deep pockets if they keep replacing hubs. Do they just replace internals or do they swap the complete hub?
I can't even pedal in the missing gears,but I did try and adjust either side of the marks,before it let go, 10th gear did seem to skip from time to time if you didn't let it 'settle ' down before applying power
simons_nicolai-uk-- are you not going to send the leaky one back under warranty?
Posted : 16/01/2012 5:51 pm
For balance, my 11-spd has been fine. Half way between it's first and second service, so 3500k on the clock..... but I know others have had problems
<sacrifices another virgin for continued reliability>
Posted : 16/01/2012 5:56 pm
Is that on or off road bristolbiker? It's nice to hear anyway.
Posted : 16/01/2012 7:10 pm
On road - thinking about this last night, what cog and sprocket are you using? Installation sheet says not to go below a drive ratio of 2:1.
Posted : 17/01/2012 10:03 am
My Alfine 11 is just a year old but hasn't done the mileage of Bristolbikers, my mileage has been mainly off road, fully laden with camping gear and included the Welsh Ride Thing and Pennine Bridleway. Gearing has been 32-20 until recently when I changed it to 34-18. I had initial problems with gears crunching and jumping out but changing the cable run to smooth out the bends and endless fiddling about with the yellow dot position has largely cured it. Sorry I can't offer any remedies or tricks but, touch wood, mine seems to be behaving itself at the moment. Finding someone to do an oil change 4 months ago was difficult but 18 bikes now have the kit if you're Peak District based.
Posted : 17/01/2012 10:23 am
Brixton Cycles sourced it for us. When the first one was returned to Madison they sat on it for c6 weeks before returning the rim and disc (ie no spokes, unbuilt wheel) and Katie really didn't enjoy the singlespeed experience so it's kind of being put off.
Rohloff say their hubs only need enough oil to coat the parts (ie it's no problem if the rest drains out) so suspect it's not really an issue.
Posted : 17/01/2012 10:38 am
I had heard Madison were a bit slow, but six weeks,quality customer service!
I'm going to nine speed mine when it's away, but thought of going back to 3x9 or even 1x9 for any length of time is really quite depressing
Posted : 17/01/2012 11:02 am
Less bothered about the time they took, more that a complete wheel was stripped and not rebuilt. We were lucky, there were a few wheels returned at the same time but the others were returned as a seemingly random collection of rims and discs (ie not what had been sent)
Posted : 17/01/2012 12:07 pm
Bugger, well mine has just left today and I am told by my lbs that they are just replacing the internals, so its gone off with the tyre still attached..and its ghettoed so if they want to take it off the rim it'll get pretty messy, mind you they will probably just snip through the spokes!!
I took everything off the wheel ( ie disc, wheel nuts etc) because I did think I would not get it back, the Ralph is about shagged anyway
Posted : 17/01/2012 1:41 pm
Update. Hub been replaced three times ( internals,ooer)
Last time back leaking oil everywhere.They sent me a new hub completely and shifter and cassette joint which I am now selling all as new ( coz they are)and sending the old hub back to them. Service from madison was appauling, they really do not know what they are doing. Will continue to ride the 8 speed while I save up to buy a Rohloff
Posted : 03/04/2012 3:43 pm
My 8-speed alfie did that in fifth gear. HTFH (who I bought it off) sent it back to Madison, who fixed it under warranty. It did take a while IIRC.
I then sold it on, freshly serviced.
My Rohloff is lovely. Had to send it back to Germany when it developed some sideways play, but Rohloff fixed it and sent it back with a letter of apology for it going wrong.
Posted : 03/04/2012 3:52 pm
