toughened glass cos...
[Closed] toughened glass costs anyone?
[#3511092]
I want to create a new wall in a room from glass. Would need to be 2.8m odd high, 1.5m odd wide, with a door in the middle...so would need 4 panels & fittings.
Any clue as to costs? I expect it to be prohibitive...(say >£1K) and yes I will ask suppliers for a quote but they're closed till Wednesday up here!
Posted : 01/01/2012 7:06 pm
Sounds right classy.
Posted : 01/01/2012 7:07 pm
Yeah, it may be crap, it may also be cool, I need to clear the room out to visualise it.
Posted : 01/01/2012 7:11 pm
Laminated would probably be cheaper as youcan get it cut off the rack where as toufghened is cut to size and then baked, and cant be recut, makes a mess if broken.
Posted : 01/01/2012 9:43 pm
Glass bricks - or is that too opaque?
Posted : 01/01/2012 9:47 pm
always wanted to build with glass bricks. When I last looked at it it seemed a bit of a faff with the metal cross bars etc and then the grout. But I imagine there's simpler systems.
EDIT: like this http://www.glassblocks.co.uk/old/neweasifix.htm
http://www.glassblocks.co.uk/old/installation/index.htm
Posted : 01/01/2012 9:50 pm
The acoustics would be truly awful. I thought you were a bit of an audio g33k?
Posted : 01/01/2012 10:00 pm
Look at office partitioning systems, as it's only 4ish m2 you should do it for under a grand.
Posted : 01/01/2012 10:03 pm
[url= http://www.christieglass.com/products.php ]Prices.[/url]
Posted : 01/01/2012 10:07 pm
http://www.optimasystems.com/glass-wall-single-glazing.php
As above. Use a specialist system, readily available via office / demoutable partition specialist.
Posted : 01/01/2012 10:23 pm
Try this: [url= http://www.expresstoughening.com/getmeasure.php ]Express Toughened Glass[/url]
They have an online form for getting a rough idea of pricing. Adam Curtis there is very helpful.
Posted : 01/01/2012 10:37 pm
Thanks guys.
Tootall it's not for a listening room. In fact it's to put an ensuite in a room at the far end from a window - to get as much light as possible. As I've said I can't decide whether it's weird or awesome.
Posted : 02/01/2012 7:37 pm
cynical - pm'd you with a photo of glass wall installed at my gaff - hope it will help with your decision making
Posted : 02/01/2012 7:53 pm
Lucky you with high ceilings... 3m, ace!
Posted : 02/01/2012 8:12 pm
I'm paying for it Markie!
Posted : 02/01/2012 8:27 pm
Just be careful when you have a drink. I built a seamless glass extension
for the old owner of Zoom Airlines years ago with a wine cellar disguised as a garden shed at the bottom of his garden and at one of his parties he came back from his shed with a bottle of wine and walked straight into the door of the extension and knocked himself out. 😆
Posted : 02/01/2012 8:32 pm
For an en-suite, I reckon the glass brick idea would work really well.
Posted : 02/01/2012 8:33 pm
did you ever visit george's old flat al? he had glass bricks separating his living room and kitchen. looked good
Posted : 02/01/2012 8:40 pm
seahouse - I'll avoid that by never ever cleaning it 😉 BTW you should give Vosh and Lobbydosser his address...
Sean & druid, aye, not sure it's the look I'm after TBH
Posted : 02/01/2012 8:43 pm
Glass bricks and put leds inside them
could even have a colour changing wall
trout - Member
It'd be even better if it could be wired to an odour sensor so it would go red when Al has been in for a shit.
Posted : 02/01/2012 8:45 pm
I have a red light outside the house anyway 😛
Posted : 02/01/2012 8:46 pm
Can the floor take such a sharp loading where you are planning? That much toughened glass would have some weight focused on a very small area. You have thought about how big the biggest piece would be to get it into the room as well?
Posted : 02/01/2012 9:26 pm
Ta - it would go across 4 joists, widest panel would get through door OK.
Posted : 02/01/2012 10:05 pm
Supaseal in Glasgow are the cheapest, but are Trade only.You could set up a Sundries account with them if you can pass yourself off as a business .I would have guessed about £40/m/sq for 4mm, more for 6mm.
They will deliver too.
Posted : 02/01/2012 11:40 pm
*bump*
It's prob a daft idea I an realising...in my ensuite I can save a 5' space by the window which is great for a desk etc and would be a bit wasted otherwise...and a glass wall would make it ligh.
But a 5' square space by a bathroom seems a bit silly when I stand in the space to visualize it...
Posted : 04/01/2012 12:12 am
just found a price in my lab book for some toughened glass we use for curing flat plates.
300x300x6mm £18 each which would tie in with the 1000x1000x4mm for £40 above taking into consideration bulk area and thinner glass.
Posted : 04/01/2012 2:03 am
Be wary that I suspect it'll be against building regs unless it comes kitemarked - friend of mine had a draught excluder (like a glass shower curtain) condemned as he couldn't prove it was certified safe. Naturally it went right back in after the completion, but something to consider.
Posted : 04/01/2012 2:33 am
