Tools for tapping o...
[Closed] Tools for tapping out the bushes/pin thing in a rear shock
[#3461948]
Hey all,
I need to swap out a shock on my bike. The new (used) one came with all the fittings for the bike it came off (a Nomad I believe).
I've got the aluminium collars off easy using a vice. However, the eyelet at the bottom of the shock also has a longer steel pin passing through it. It's drilled to take the bolt that holds the shock onto the frame. Like the one 5 down on this page: http://www.mojostore.co.uk/acatalog/Fox_Rear_Shock_Bushing_Kits.html
I'd tapped it half way out using a hammer with a socket set bit underneath. The problem is, the pin is much longer than the depth of the socket, so I can't use it to tap it all the way out. Additionally, the socket was starting to mark the shock.
Does anyone know if there's a proper tool you can buy that lets you do this job quickly and easily. Alternatively, any ideas for a makeshift drift and nylon support?
Hope this makes sense to someone 🙂
Posted : 14/12/2011 11:17 pm
open your vice slightly, put something soft on the jaws to rest the shock on & tap it through with a drift.
Posted : 14/12/2011 11:19 pm
Can you not cut the pin (assuming it is not being reused)
Posted : 14/12/2011 11:21 pm
BETD or tftuned sell them roughly about £25
Can you use some blocks of wood underneath the shock? I've used old allen keys as punches when I've been stuck for something to knock bearings out of frames.
Posted : 14/12/2011 11:25 pm
The tool is a bushing tool im assuming he means. You can pull them out with a selection of sockets and a long bolt and nut or just drift it out with a couple of sockets and a hammer. Or put pin in the vice and spin the shock off.
Posted : 14/12/2011 11:26 pm
Cutting the pin would just leave it stuck in the shock, unless I've misunderstood what you mean Mark?
The only thing I can see on BETD is this: http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=375&Name=Shock+Eyelet+removal+tool which seems to just be fore the little eyelet bushes.
A couple of bits of wood on the vice might work - just seems like a pretty crude method. There must be a clever way!
