Tip of the Day (and...
[Closed] Tip of the Day (and associated QR question content)
 al_f
[#1613987]
Tip: if a QR skewer is apparently stuck in your rear hub, do not bang the drive-side end of the QR on the ground in an attempt to free the skewer and allow you to replace it. If you do, the entire cassette and freehub body will fall off, spilling its delicate springs and pawls onto the ground necessitating both an expletive-filled search for the fallen parts and a premature end to the morning's ride.
In related news, anyone got any idea how to get the damn thing out? Soaking overnight in WD-40 and a large hammer have so far failed, it's apparently seized solid. I only regreased it a couple of weeks ago too. 🙁
Posted : 16/05/2010 8:28 pm
Hope hub?
Posted : 16/05/2010 8:32 pm
 al_f
Yes - is it a "known issue" (the sticking I mean, not the falling out and spilling its guts on the floor bit), or was that just a lucky guess?
Posted : 16/05/2010 8:36 pm
No,never happened to any of mine. It was just that the freehub comes off really easily and can let go of the pawls and springs if you're not careful.
Posted : 16/05/2010 8:45 pm
 al_f
Well, a further overnight in the wd-40 and it still won't shift. Any ideas?
Posted : 17/05/2010 9:33 am
Just one more reason you've got to love single speeding 🙂
Posted : 17/05/2010 9:46 am
I'd be amazed if my shimano freehub popped off that easily, I normally require at least 20 minutes with a chain whip and cassette tool to get it to pop off the freehub lol.
Posted : 17/05/2010 9:51 am
 al_f
Yeah, my first reaction was "I didn't think they could do that". 🙄
Posted : 17/05/2010 9:54 am
g clamp over cassette/freehub.. then **** the skewer with a soft faced hammer.
Posted : 17/05/2010 9:58 am
coffeeking - Member
You use a chain whip to get your freehub off?
Posted : 17/05/2010 10:08 am
That's why it takes so long.
Posted : 17/05/2010 10:17 am
A Shimano freehub couldn't drop off without shearing the huge bolt that holds it onto the hub body. The Hope freehub doesn't use a bolt.
What exactly is the QR skewer seized onto? Do you have any pictures of the mess?
Posted : 17/05/2010 10:26 am
hope freehubs don't take much persuasion before they slide off and spill their guts all over your kitchen, i liberated mine takin a cassette off.....
gives you a chance to clean and re-grease it!
Posted : 17/05/2010 10:31 am
To get The stuck QR out your gonna need to rest the wheel on the open jaws of a vice and with an old QR or something with a simmilar diameter try and tap the qr through the axle, when it moves a bit turn the wheel over and tap it back. Everytime it moves squirt some oil in, it will eventually come out. I doubt you will pull it out. Next time, grease the shaft of the QR before you put it in!
Posted : 17/05/2010 11:23 am
Soak in PlusGas - it's designed exactly for this sort of thing. Make up a funnel with Plastacine to ensure that it gets a good soak and leave the wheel flat over night so that the Plusgas can runn down the skewer.
Posted : 17/05/2010 11:44 am
 al_f
Three_Fish - Member
It's seized inside the axle. Thanks for the PlusGas/plasticine funnel tip, will give that a go. I did grease it (only about 2-3 weeks ago!) which is why I can't understand why it's so stuck...
Posted : 17/05/2010 12:42 pm
I don't know Hope hubs but might it be that the axle is bent along with the QR and so its not releasing?
Pics would help.
Posted : 17/05/2010 1:01 pm
