Shimano I-spec shif...
[Closed] Shimano I-spec shifters - more space for a reverb button ?
[#5049014]
Possibly going 10spd soon as most of my drivetrain is worn, do the I-spec shifters give you more useable space to add a reverb? They dont play nice with standard shifters (RH on LH used underneath)
Posted : 09/04/2013 3:17 pm
I think your 'verb' will still interfere with the shifters, if it's mounted wrong-ways-up. But the button comes with an i-spec mount, can you not mount the button to the brake mount instead?
Posted : 09/04/2013 3:20 pm
 DrP
Reverb = SRAM
i-spec = shimano
They won't play nice together....
DrP
(i.e the rev lever won't mount to XT i-spec brakes, but if the shifters were i-spec, you can move the rev lever closer....)
Posted : 09/04/2013 3:21 pm
They can do, i mounted mine using the Hope adaptor for my brakes (Hope obviously). It allowed me to mount the reverb lever upside down, but there's not a lot of adjustment once the lever is position against the brake lever.
Posted : 09/04/2013 3:22 pm
Go 1x10, then you'll have loads of room! 😀 (and yes, i-spec on the RH side 😛 )
Posted : 09/04/2013 3:26 pm
I hate the reverb remote, why do RS make their remotes so bulky? I bought a LH one to fit to the right under the bars and then found out how much of a pain it is with shimano shifters and brakes. Kind of wish I had just bought a RH one now and put it above the bars but under the bars is a much nicer position for your thumb.
I have now made my own version of i-spec for older 9 speed shimano shifters and XT 775 brakes.
Posted : 09/04/2013 3:30 pm
 DrP
SHARE, SHARE!!!
I was thinking of doing this...
DrP
Posted : 09/04/2013 3:31 pm
I had my right hand Reverb lever upside down on the left with XT i-spec shifter/brake lever.
It is tight space wise and I needed to fiddle with the positioning a bit but got there in the end. Only negative was that to alter the return speed adjuster I had to loosen the clamp to free things off a little.
Here's a pic of the way I had it set up!
Posted : 09/04/2013 7:30 pm
Dr P - will send you some images of mkII when i get it made. mkI is okay but a bit rough and a few kinks to work out.
j40aja - what is that black part filling the gap in your reverb remote clamp? I just have a gap there on mine, am I missing something?
Posted : 09/04/2013 7:33 pm
I think it's to do with the MMX part of the clamp if you bought a Reverb with that option. If you attach to SRAM brakes/shifters then that black piece comes out like matchmaker/i-spec systems.
Posted : 09/04/2013 7:39 pm
I've got the mmx part which sits in the opening on the clamp band. But nothing like that. Off to the sram website to look at the parts diagram...
Posted : 09/04/2013 7:40 pm
