here's a clue why we asked
http://www.mountainbikecomponents.co.uk/result.asp?CategoryID=18&Name=CHAINRINGS
that chap up there is the funny ring king. drop him an email and let him know what size you want and he'll sort you out as it were.
because biopace is 5 arm you can't rotate it 90 degrees...
You could rotate them enough to give you a bigger gear in the power stroke though. That's what I did when it was all trees because they hadn't been felled for fields yet. Then I discovered the insanity that is round rings.
yes Will,but you're just a freak......
I LOVE GOATS.
Anyone heard anyhting on these yet?
sent an e mail but no reply......
Elf=ring piece
Guys,
I have been offering some Biopace rings here for weeks, waiting for this type of posting to come along.
Biopace were for 7-speed, so use a 3/32" chain.
They were without pins and ramps, so could be put on 'inside-out' and rotated one hole to give the 'power' position mentioned above.
I have the following items that are still up for grabs:
LX M500 crankset, 170mm Square Taper, with 48T Alloy Biopace, 38T Alloy Biopace and 24T Steel Round all on 110/74mm BCD, very nearly new.
Silver 48T steel Biopace 110mm ring
Black 48T steel Biopace 110mm ring
Black 38T steel Biopace 110mm ring
Black 28T steel Biopace 74mm ring
Silver 28T steel Biopace 74mm ring
Mail me for more details if interested.
paul.r.davisAThotmail.co.uk
Paul; bung 'em on Retrobike. They'll soon shift!
Elliptical rings work* - in fact you soon get so used to them that round rings feel funny when you go back to them...
* when correctly orientated!
You must log in to post.
