Problems downloadin...
[Closed] Problems downloading ride data from Garmin Edge 705 to TC and Garmin Connect...
[#3165042]
I have an Edge 705 that all of a sudden won't download the rides that I have done to either the Training Centre or to the Garmin Connect. It worked perfectly up until a few months ago and now nothing transfers over......very frustrating !!
Any clues as to what to do ???
Thanks
Sean
Posted : 20/09/2011 10:00 am
is the device recognised by your pc (ie. does the garmin software start automagically)?
Posted : 20/09/2011 10:01 am
yep it does, goes through all the rigmarole and looks like it has worked but then nothing goes into the TC, same with Garmin connect.
Posted : 20/09/2011 10:09 am
Are the rides being saved to the history properly?
Posted : 20/09/2011 10:11 am
Nope, thats the problem.
Posted : 20/09/2011 10:13 am
Is there enough spare memory so the device can save them?
Posted : 20/09/2011 10:17 am
I give in ? How do I find that out ?????? I connect it everytime I ride, until the 10th May it worked perfectly, but I looked through the history last night and nothing has downloaded since then. As I say, it looks like its working perfectly, it does the whole "downloading information from the handheld" and then you get the line on the screen thing saying 4 minutes to go and then basically nothing seems to happen. It is exactly the same on garmin connect.
Posted : 20/09/2011 10:20 am
connect the device and look at properties on explorer, if there is something like 100kb left then there isn't enough. I did a reformat of my forerunner 110 last week, got the default files from garmin support and works perfectly now.
You have called garmin support right?
Posted : 20/09/2011 10:25 am
If you go
Menu > Where to > Saved Rides
are the rides there?
Can you do a manual upload from file, rather than automatic download from the device?
Posted : 20/09/2011 10:32 am
All the rides are saved in the History but not in Saved Rides, I thought that Saved Rides was just for the files that you download about sportives or the like.....
Will try the manual upload.
Posted : 20/09/2011 10:57 am
Tried manual upload, says there is an error uploading from the file.
Posted : 20/09/2011 11:00 am
dgjlover it looks like thats the problem, 335Mb available, 336Mb on disk.....
I'll try garmin support.
Thanks
Posted : 20/09/2011 11:02 am
